Hi all,
I have a harmony remote however I also have an apple tv so I need to reserve the Bluetooth radio for that, as I learned the hard way I can’t have both.
I was redoing my setup which allowed me to Add the Vero back in and I was trying to do stuff however the remote won’t work properly. The only button on the remote that works is the back button. I’ve tried changing the remote settings in my OSMC countless times to every remote under the sun and again the only button that works is the back button.
I see a blue light, and have changed the battery, and even when I try to unpair the remote things don’t work properly. When I press home and ok, the blue light never flashes it just stays on. When I remove/add the usb dongle again the blue lights immediately blinks three times and goes away.
I don’t know what else to do here. I’m using my phone but the on screen remote is far from ideal.
I would also love to figure out what I need to do to set up OSMC to work via my harmony remote with IR, I’ve seen a few links to people wanting to do that but it’s limited at best and doesn’t provide an easy step by step on what to select through the harmony setup to make that work.
Thanks in advance.
