IR Remote not working when watching video
Sam,
This is really frustrating that this has been unresolved for over a year. My video performance is poor when MPEG2 acceleration turned off and remote performance is poor when MPEG2 acceleration is turned on.
It’s still on the list – but it’s a lower priority as not many users are using IR remotes at the moment.
I know that my particular use is unique because I use multiple IR remotes that I want to decode separately, so I can’t use eventlircd. As such, using USB receivers is not an option (unless there is some way to route that to lircd).
Understood.
I’m not exactly sure what your use case is here but the FLIRC USB IR receiver I mentioned earlier in this thread would work with more then one IR remote. When you program it you just send it an IR signal and tell it what keyboard key to assign that to and that is what happens when you plug it into your media player. It really doesn’t care what remote any given input is coming from and if you want to get really unique with your keyboard commands it supports sending modifier keys. You should be able to get anywhere you want to be with that and and maybe a bit of Kodi keymapping (if your wanting to deviate from Kodi stock mappings) without LIRC.
darwindesign: I am not sure that what you are describing fits my situation. Simply put, I have two remotes with different codes. Each has a Play button. I want the Play button on one of them to have a different action than the Play button on the other. If the signals are routed through eventlircd, the two buttons are translated to the SAME action.
With lircd, I can retain the source information and have separate actions. In a different thread, DBMandrake said that USB receivers are not routed through lircd:
Using lircd, my USB remote shows up in mode2, but does not show up using irw. I am not sure how to get past this.
When you program it on a PC you can set one remote to send ā€œpā€ and the other to something like ā€œalt+pā€ and then make a keymap for Kodi to assign a kodi action for <p mod="alt">. This gets you to the same place you were before but you also gain some responsiveness and the ability to do long-press actions (holding down a button can perform a different action than a regular short press).
At one point, I did go down the route of alternate names, but the obscure naming didn’t appeal to me. I may have to go back down that rabbit hole if this doesn’t get fixed. Or maybe switch over to Raspberries, since I think that lircd still works on those.
I did figure out how to get the USB receiver to work with lircd, but it ignores the first button press. Now that I went through that again, I remember being there before. I wish I had a better memory.
Anyway, I am stuck with what I have and can only hope that it gets fixed one day.
We will definitely get it fixed.
Hi @sam_nazarko,
I hate to be ā€œthat guyā€ but are there any updates on this please? - it has been 2 years!? :frowning:
I see the Vero V has IR - will this still be a problem on the Vero V?
Thanks,
Jon.
Not at all.
Still being worked on. Hopefully we will have some improvements in a new kernel.
I’m suffering this exact same problem after finally updating (can’t recall just how ancient a version I was on before) to 20.2.0 (Git 20240815-OSMC). Both my trusty old Raspberry Pi devices are working flawlessly, but the Ir on the Vero 4K becomes unresponsive when it’s in video playback mode. When it’s not playing video, the Ir works perfectly. I’m kind of stuck with Ir as (aside from wanting to use a single remote control for the Vero and Monitor) I never managed to get to the bottom of the problem where my official remote would chew through a fresh battery every day.
@sam_nazarko I appreciate that a ā€œme tooā€ post isn’t particularly helpful, but do please let me know if you want a volunteer tester when there is something to try.
Cheers,
Fergus.
We are still working on this. The next kernel (5.15) has changes to how video IRQs are handled and we will check from there.
4 years later and there is still no solution. I made the mistake of upgrading my Vero 4k+ to the latest release and now that I know that it’s out of support, it’s clear that there will never be a fix. That’s too bad.
edit: Hmm, it seems there isn’t even a download available to re-install the Vero 4k+ with an image version that has working IR support. The oldest download is from 20240801 and that is far beyond the point where IR support was broken.
That’s not true.
I suggest to see Index of /osmc/osmc/download/installers/diskimages which will allow you to download any version of OSMC ever released for Vero 4K / 4K +.
Vero 4K + is indeed end of life unfortunately.
Oh, thank you. I was looking at the download section of the site and that has only three disk images for the Vero 4k / 4k+. Maybe you could add a link to the full repository there.
I was able to re-install and restore the complete configuration. Now the box runs flawlessly again on mediacenter 18.9.0-4. It’s still a great media player. :+1:
I’m not particularly keen on this as I’d prefer users run the latest version of OSMC for the best experience.
