ID 1d57:ad02 Xenta SE340D PC Remote Control
(Tested on RPi 3)
For less than $4, free shipping from ebay, this remote set was detected and can be used as a keyboard and a mouse.
- Use in Kodi without any settings. (no more CEC hassels)
- Use as a keyboard to select an OS in NOOBS boot menu.
How to customize with keymaps:
Copy this code to /root/osmc/.kodi/userdata/keymaps/keyboard.xml
Edit mapping as you like. (use either ‘key name’ or ‘key id’)
Restart (Power > Exit) once to load the file.
Then on finish editing, just press the green button to ‘ReloadKeymaps’ without restart.
<?xml version="1.0" encoding="UTF-8"?>
<!-- ### custom keymaps for 'ID 1d57:ad02 Xenta SE340D PC Remote Control' ### -->
<tab> SystemInfo <-> Back | FullscreenInfo <-> Back
<open> MovieTitles | MovieTitle <-> Fullscreen
<switchwindow> Settings <-> Back | VideosSettings <-> Back
<blue> NextSubtitle
<yellow> AudioNextLanguage (next audio language)
<amber> OSDAudioSettings
<green> ReloadKeymaps (without restart)
<keymap>
<global>
<keyboard>
<!-- e-mail --><launch_mail><launch_mail>
<!-- www --><homepage></homepage>
<!-- close --><f4 mod="alt"></f4>
<!-- yellow --><d mod="ctrl,alt"></d>
<!-- blue --><c mod="ctrl,alt"></c>
<!-- amber --><b mod="ctrl,alt"></b>
<!-- green --><a mod="ctrl,alt">reloadkeymaps</a>
<!-- tab --><tab>ActivateWindow(SystemInfo)</tab>
<!-- start --><key id="2159104"></key>
<!-- open --><o mod="ctrl">ActivateWindow(Videos,MovieTitles)</o>
<!-- esc --><escape></escape>
<!-- switchwindow --><key id="323593">ActivateWindow(Settings)</key>
</keyboard>
</global>
<FullscreenVideo>
<keyboard>
<!-- yellow --><d mod="ctrl,alt">AudioNextLanguage</d>
<!-- blue --><c mod="ctrl,alt">NextSubtitle</c>
<!-- green --><a mod="ctrl,alt">ActivateWindow(osdaudiosettings)</a>
<!-- tab --><tab>ActivateWindow(fullscreeninfo)</tab>
<!-- switchwindow --><key id="323593">ActivateWindow(VideosSettings)</key>
</keyboard>
</FullscreenVideo>
<FullscreenInfo>
<keyboard>
<!-- tab --><tab>Back</tab>
</keyboard>
</FullscreenInfo>
<MyVideoLibrary>
<keyboard>
<!-- open --><o mod="ctrl">Fullscreen</o>
</keyboard>
</MyVideoLibrary>
<SystemInfo>
<keyboard>
</keyboard>
</SystemInfo>
<Settings>
<keyboard>
<!-- switchwindow --><key id="323593">Back</key>
</keyboard>
</Settings>
<VideosSettings>
<keyboard>
</keyboard>
</VideosSettings>
</keymap>
If you want to a fully customizable remote, you need this:
JP1 Remote - The ultimate solution of a remote.
It’s like Raspberry Pi of ir remote world.
