I’m new here. I use OSMC now for a few months on the Rpi. The sound is connected with a externe Soundblaster USB to my 5.1 Audioreciever. The screen is an LG HDMI TV.
There is also a externe SataHD and a externe Sata Blu-ray player connected (both USB)
My question is: Is it possible to connect my oldscool recordplayer with a ION USB U-recorder/player to OSMC to play records with the Rpi and OSMC?
On my computer with Kubuntu I’m using Audacity to play/record the good old vinyl. It uses USB Audio Codec.
You can try to connect it and then install the alsa-utils package via ssh.
Then use alsamixer to turn up the volume on the usb soundcard and start the record.
You won’t be able to integrate it into kodi though.
Edit: You might also need to add dtparam=audio=on to your /boot/config.txt
Thanks very much for your answer @mcobit
I couldn’t find very much info about this but now I found 14 topics on alsa-utils. I’ll read them and play with the alsa-utils. If it works I’ll report it here.
