Hi everybody and Sam thank you very much for the atv1 version. Just a question, is the airplay working with OSMC because I have tried it and it doesn’t work for me. Am I doing something wrong?
Please let me know.
Check out Using AirPlay - General - OSMC for some information.
Let me know if you have any questions
Thank you for your answer. I will just have to wait until airplay is available.
Did you read the article? AirPlay is presently available.
I’ve read it, I have IOS 9 and it doesn’t work for me (although I’ve tested it with an old iphone with 7.1 firmware and still didn’t work and I have done all the proper actions - setting/ enable airplay - with no luck)
Just double checking, do you have Zeroconf enabled? I believe it needs to be enabled for AirPlay to work.
Regarding Airplay …
I have an Airport Express connected to my amp, is there any chance to stream music from OSMC to the Airport?
It seems that this is not supported by Kodi.
What about OSMC? Is there a workaround like Pulseaudio?
Thank you
Nothing works unfortunately for me
Other possible causes:
osmc and the airplay device not being connected to the same network
router not allowing multicast traffic
Airplay from iOS 9 devices is not working for Kodi 15.2 (Isengard) on any platform, so there’s not much point in trying (and failing) to get it working on the Apple TV.
Jarvis will apparently fix Airplay Audio again but not Airplay video.
