I mean, can you change the play settings from play once, repeat, repeat all etc from the remote out of the box?
Do you mean to ask if it is possible to change the default action so that when you press play it repeats?
No. This might be a stupid question but i just mean with the remote that comes with a 4k+ is it possible to change the play settings at any time?
You’d need to select it in the menu as there’s no key dedicated to this function
