I have a RPi2 inside our bedroom and sometimes my daughter would be having her sleep in our room. I dont have a dedicated baby monitor and have been using motioneye to monitor our baby when im out of the room.
As I only have 1 RPi2 and cant afford to buy an extra yet, I thought I would try to install motioneye on top of osmc. I have been following ccrisan/motioneye installation guide for Debian but to no avail.
I thought I could I ask the community if this has been done and if anyone could help me. Thanks!
I have executed all steps without any errors with the exemption pip install motioneye, but that has been resolved by issuing apt-get install build-essential python-dev. All steps have been completed however motioneye is not starting (rpi2IPAdress:8765). And i dont know where to look where is the problem.
I would:
a) sudo apt-get install htop then execute with htop to see if motioneye is actually running.
b) Port forward port 8765 to my pi’s lan ip, just in case…then try to connect again. (and ofc set a fixed lan ip on the pi)
Well if its not running then maybe you can find the reason why in the log files.
I dont know where it stores its log files…check maybe inside:
/usr/local/share/motioneye/
or
/var/log/motioneye.log
Hi guys! I’m facing the exact same problem @cdalid describes. I followed the guide without error on OSMC but still I cannot access the motioneye web interface.
So, to answer the last question, I cannot find the motioneye.log file anywhere. It seems to fail so hard that not even the log file is initialized.
