Is it possible to install openjdk-8-jre-headless on RPi4?
I need it to install the unifi controller, and I prefer not to use docker.
Why not try it? I imagine it will work.
In the official repositories there is only version 11, openjdk-11-jdk-headless, which does not work with the unifi controller.
Is it possible to add some old repository, debian, raspbian?
I would like to install the unifi controller also on my vero but im only familiar with relative simple installs. So a step by step guide would be cool ,if someone knows how to do this. Tom
Looks like it should work with docker:
Thanks Tom.
Is this the same for vero?
So every sudo is a new command Line i should type in SSH?
I canāt see why not
All the lines except change IDs (this are the edits) need to be run.
Thanks Tom.
Could you simplify this text a bit? So what i need to give in SSH as command. If its not to much Trouble⦠Im still learning to use the command Line. Thanks in advance
Not really, its list of commands that need to be run. This should help:
Thanks Tom.
Ok i understand but i mean could you delete the lines of the id in the text above. Because i dont know exactly where to start and finish the chance of linesš
Change id= are changes to /etc/os-release. You need to find the line in that file and update as advised.
Thanks Tom.
ok sorry still noobish here ![]()
this is what i get after installing the first line in ssh
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sun Nov 14 10:10:42 2021 from 192.168.0.178
osmc@osmc:~$ sudo nano /etc/os-release=osmc
osmc@osmc:~$ sudo sh get-docker.sh
sh: 0: Canāt open get-docker.sh
osmc@osmc:~$ curl -fsSL https://get.docker.com -o get-docker.sh
Executing docker install script, commit: 93d2499759296ac1f9c510605fef85052a2c32be
sh -c apt-get update -qq >/dev/null
sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl gnupg >/dev/null
sh -c curl -fsSL āhttps://download.docker.com/linux/raspbian/gpgā | gpg --dearmor --yes -o /usr/share/keyrings/docker-archive-keyring.gpg
sh -c echo ādeb [arch=armhf signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] Index of linux/raspbian/ buster stableā > /etc/apt/sources.list.d/docker.list
sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq --no-install-recommends docker-ce-cli docker-ce >/dev/null
osmc@osmc:~$
Just tried to set this up on my test vero4k. Slight change in instructions, so please revert any previous changes and try this:
sudo update-alternatives --set iptables /usr/sbin/iptables-legacy
Then follow the instructions for installing docker from here:
Then finish the unifi installation with:
sudo usermod -aG docker $USER
sudo apt install docker-compose
sudo reboot 0
mkdir unifi && cd unifi
curl -O https://raw.githubusercontent.com/ryansch/docker-unifi-rpi/master/docker-compose.yml
sudo docker-compose up -d
Thanks Tom.
Thanks a lot name mate
i got it all installed now, one more question,
How do i start the controller now in osmc , is it only ssh or can i see the controller on my tv screen now?
thanks in advance
Tom
Sorry donāt a lot about the unifi controller. More can found here though:
https://hub.docker.com/r/ryansch/unifi-rpi
Thanks Tom.
i go to cd unifi
and then i go to sudo service unifi status
it says service not found
ok i understand , i have got a step further thanks to you, maybe if someone else reads this they can help further.
Thanks a lot
