Sorry for my (maybe) stupid question : I had a Vero 4K box connected to an ACER m550 4K projector.
It seems this projector cannot display correctly HDR with 420 encoding : it must receive 444 instead.
My sources are UHD MKVs files all encoded with YUV 420
Does exist a way the Vero box is able to transcode (somehow???) the source and output a 444 signal to the projector ?
echo ā444,10bitā | sudo tee /sys/class/amhdmitx/amhdmitx0/attr will probably do it for you.
Awesome ! That works perfectly now !
Many thanks !
I realize this attr file does not persist in case of reboot of the device. How to make it persistent ?
You would need to put the command into your /etc/rc.local
file before the exit 0
to make it load at boot time
Thanks but I added the command in the rc.local file as below
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
echo '444,10bit' | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
exit 0
After reboot there is no attr file existing. I do a check by
sudo cat /sys/class/amhdmitx/amhdmitx0/attr
that returns nothing. So I did the command manually with ssh then the cat returns the right parameters.
Did I miss something ?
/etc/rc.local runs as root, so the line should be
echo '444,10bit' > /sys/class/amhdmitx/amhdmitx0/attr
Thanks. I tried several times and attr file remains empty
Please show your updated rc.local
In the next update Iāll add this option to the GUI.
#!/bin/sh -e
# rc.local
# value on error.
# bits.
exit 0
I tried various syntaxes
echo '444,10bit' | tee /sys/class...
echo '444,10bit' | sudo tee /sys/class...
Then I did a reboot on ssh. After rebooting I checked with
And it is empty.
You have extra spaces after echo
Well, thatās really strange. I changed rc.local weeks ago and
always gave the reply 444,10bit
Today I saw this thread and out of curiosity I checked and the reply was empty.
My rc.local:
#!/bin/sh -e
# rc.local
# value on error.
# bits.
exit 0
I see this:
Last login: Fri Mar 16 18:51:01 2018 from 192.168.1.2
osmc@vero4k:~sudo cat /sys/class/amhdmitx/amhdmitx0/attr
osmc@vero4k:~$ echo ā444,10bitā | sudo tee /sys/class/amhdmitx/amhdmitx0/attrtr
ā444,10bitā
osmc@vero4k:~$ sudo cat /sys/class/amhdmitx/amhdmitx0/attr
ā444,10bitā
I upddated to 2018.3-2 a few hours ago. Sadly I canāt say since when the entry in rc.local has been ignored - havenāt checked for quite a while.
On the other hand I did not notice any changes in the picture quality, so the line does not seem to matter in my setup anyway (AVR: Yamaha RX-V483 / TV: Sony XE9305)
Can you run grab-logs -A
for us? I guess itās possible that rc.local isnāt running.
Also whatās the output from running systemctl status rc-local
hmmm, that looked differently in the past as far as I remember
osmc@vero4k:/etc$ systemctl status rc.local
* rc-local.service - /etc/rc.local Compatibility
Loaded: loaded (/lib/systemd/system/rc-local.service; static; vendor preset: enabled)
Drop-In: /lib/systemd/system/rc-local.service.d
`-debian.conf
Active: inactive (dead)
Logs available at https://paste.osmc.tv/nuquciveci
looking better now
osmc@vero4k:/etc$ sudo systemctl daemon-reload
osmc@vero4k:/etc$ sudo systemctl start rc-local
osmc@vero4k:/etc$ systemctl status rc-local
`-debian.conf
Active: active (exited) since Fri 2018-03-16 19:31:56 CET; 5s ago
Process: 2904 ExecStart=/etc/rc.local start (code=exited, status=0/SUCCESS)
Mar 16 19:31:56 vero4k systemd[1]: Starting /etc/rc.local Compatibility...
Mar 16 19:31:56 vero4k systemd[1]: Started /etc/rc.local Compatibility.
Now letās see, what it does after a reboot
SOLVED - well, it works
to be honest - I am not sure, what I did or what happened, but after editing rc.local again and rebooting, voila
Last login: Fri Mar 16 19:06:49 2018 from 192.168.1.2
444,10bit
Sorry for disturbing. As in most cases the problem was sitting in front of the computerā¦
