I would like to get spotify connect on my RPi, but the only thing I can find is GitHub - Fornoth/spotify-connect-web
And from what I can see it runs as a webserver. Is possible to run that on OSMC?
If there happen to be better Spotify Connect option then please paste
I dont see why not.
I am running a php/mysql webserver on my pi, serving 3 websites.
I dont know Spotify Connect, but i’ve found these:
http://forum.kodi.tv/showthread.php?tid=125147
#Prerequisites
You need a PREMIUM account nothing else works since Spotify doesn’t allow ARM devices to use free accounts for streaming this is their policy so complain to Spotify and not the developers about free not working.
And if it doesn’t work after you followed these steps report it to appropriate developers, i can try to help but i only have limited time to do support work.
For Spotlight support use this link
https://bitbucket.org/re/spotlight/issues?status=new&status=open
For Pyspo…
http://geeks.noeit.com/turn-your-raspberry-pi-into-a-spotify-server/
How do I install a webserver on OSMC, I cant see it in the store
For this spotify page you showed i think it’s making its own webserver. You dont need to install one on your own.
So I would have to SSH into it and then install it that way?
yup,
You might wanna enable root password, to make your life easier…instead of type sudo all the time, before every command.
Log in with osmc/osmc for user and pass, then type sudo passwd root and type your new root passwd
Then log in as root with: su root and your new password.
Then do all the installation stuff.
If i was you, i’d backup my pi SD card with this: Win32 Disk Imager - Browse /Archive at SourceForge.net
so if anything goes wrong, i can always restore back to this image.
THEM
26 March 2016 13:04
9
Or, of course, just type “sudo bash” then do whatever you need to
