I am running into a problem whereby, I think, my Synology 218+ keeps resetting/losing the write permission on my NFS mount. I tried Fstab and Autofs and both work fine for playing files but when I need to write to the mounted folders, and I really only do this for downloading subtitles, it will work for a few days but then will lose the write permission. When I reset the permissions on my Synology everything will be fine again for a few days but the the whole thing will repeat itself.
I read somewhere that Synology is a little bit shaky on the NFS side and it could have to do with the Squash settings. I have it set to: All users set to Admin and Synology would reset these squash settings automatically after a few days, but I am not sure if that’s true.
I am really not a computer wizz so I would like to know if it’s possible to set additional read and write permissions in autofs or fstab?
I used this how-to, to mount my NFS Shares on my Vero 4k plus and my Raspberry Pi
and previously used Fstab via this guide:
if someone could help me out it would be much appreciated
Sounds like something is running on the Synology that is resetting the file permissions. There isn’t really anything you can do from a mount if the NAS is changing permissions on the filesystem. Can you SSH into the NAS to verify the actual permissions and owner of the files?
Ok I get it al working after checking the right boxes in Shared folder/Permissions as well as in File Station/properties/permissions.Only when I restart the Synology all of the settings are gone/boxes unchecked and therefore lose all writing permissions. I can still access the shares though.
I finally found the cause why my nsf folders kept losing the set permissions. I am running two docker containers on my Synology that are causing the problem. It’s the Haugene/Transmission-openvpn docker container which downloads torrents to my nfs shared folders and somehow resets all of the permissions, not only on the folder side but also the user permissions on my Synology. I changed the destination folder in the docker containers and the problem is solved.
