pi@raspberrypi:~ $ apt-cache show gstreamer1.0-omx
Package: gstreamer1.0-omx
Source: gst-omx1.0
Version: 1.0.0.1-0+rpi18rpi1g
Architecture: armhf
Maintainer: Andrew Lee (李健秋) <andrew.lee@collabora.co.uk>
Installed-Size: 287
Depends: libc6 (>= 2.4), libglib2.0-0 (>= 2.37.3), libgstreamer-plugins-bad1.0-0 (>= 1.4.4), libgstreamer-plugins-bad1.0-0 (<< 1.4.5), libgstreamer-plugins-base1.0-0 (>= 1.2.2), libgstreamer1.0-0 (>= 1.2.0)
Homepage: http://gstreamer.freedesktop.org/
Priority: optional
Section: rpi/libs
Filename: pool/main/g/gst-omx1.0/gstreamer1.0-omx_1.0.0.1-0+rpi18rpi1g_armhf.deb
SHA256: 3316e957618375976e8674d1e8bab6b6fe4134884fcdf913673a33ef6da2d89e
SHA1: e51db86dfafde660a1922f98f17936339bffe8ee
MD5sum: acba5b7e2e97c7ba84b3f0f335e78fa6
Description: GStreamer OpenMAX plugins
GStreamer is a streaming media framework, based on graphs of filters
which operate on media data. Applications using this library can do
anything from real-time sound processing to playing videos, and just
about anything else media-related. Its plugin-based architecture means
that new data types or processing capabilities can be added simply by
installing new plug-ins.
This module provides a plugin that allows communication of GStreamer
with OpenMAX IL components, which are used to access hardware
encoders and decoders.
Description-md5: c5afe98ddc31967645786ee960bc7303
Source: gst-omx1.0
Version: 1.0.0.1-0+rpi13+jessie
Architecture: armhf
Installed-Size: 254
Depends: libc6 (>= 2.4), libglib2.0-0 (>= 2.37.3), libgstreamer-plugins-base1.0-0 (>= 1.0.0), libgstreamer1.0-0 (>= 1.0.0)
Priority: optional
Section: rpi/libs
Filename: pool/rpi/g/gst-omx1.0/gstreamer1.0-omx_1.0.0.1-0+rpi13+jessie_armhf.deb
SHA256: 69b5107e0d10b7daf4767c096fe7cc1e873e8a88bb698a1c46a85feba2bd750c
SHA1: 38cf9cb0ebdcbe51d4b0aa798122c129defc0a25
MD5sum: 405b4da202e2a80280d2e84682472852
I’d hazard a guess that the second one (gstreamer1.0-omx_1.0.0.1-0+rpi13+jessie_armhf.deb) might be more appropriate but it’s just that: a guess.
Edit: Nope. On my jessie Pi 1 it installes the first one: Inst gstreamer1.0-omx (1.0.0.1-0+rpi18rpi1g)
