Topic says it all… I have a UHS-II sdxc card and need to decide if I’ll use it in the microsd slot directly or in a USB 3 UHS-II adapter since I’ve read the latter outperforms UHS-I.
Thanks!
Thanks!
The Vero 4K/4K+ only has USB 2.0 ports.
We can only take advantage of UHS-I. But I would use the microSD directly and avoid adding another potential point of failure.
Ok, thank you for the clarification.
