When I’m browsing files with longer names on an external hard drive, the filename will auto-scroll when it’s too long for the display, but it is sooooo slowwwww.
Is there any way to speed this up so it’s less infuriating?
Which skin are you using?
Aeon TAJO
Then you should contact the skin maintainer over at the Kodi forum or the respective GutHub repo.
Thanks! I wasn’t sure if that was a function of OSMC or the skin itself.
