I have been patiently waiting for a successful HD install of OSMC on my ATV1. However, I would, in the interim, upgrade my Kodo14.2 to 15.2. Is there a relatively easy way to do it?
I am aware of OpenElec and Sam’s efforts on OSMC. I just would like to update my systems while I wait
I am a bit of a noob - Is there a step missing or am I doing something wrong; when Kodi restarts, it boots back into Helix not Isengard? I followed your archived instructions in the past with another ATV and it worked like a charm but I can no longer access these to see where I went wrong this time
just remember cb2 has no support so if you run into trouble it would get tricky when OSMC has the supported needed for HDD installation is recommended that you change to that this is just a quick fix not a permanent solution
Three issues, there is no Crystal HD support in the version that will be downloaded.
The Config manager will be missing.
And it will install to a different location compared to the Crystalbuntu version and will not even run on boot. Plus a bunch of other compatibility issues.
So pretty useless really. You will have to wait for Sam to sort HD installs out.
