I like to listen to dnbradio.com and bassdrive internet radio. Is there a way to open these from the main UI?
Just have a look at the Radio addon. It should offer tons of international radio stations: https://kodi.wiki/view/Add-on:Radio
Thanks for the suggestion. The radio addon does have dnbradio but not bassdrive. I can’t see a way to open up a radio stream from a custom URL in there.
Is there a radio addon that can open up custom radio links? I sometimes listen to audio podcasts and they will not be available through any app with a list.
There seems to be a way, which I haven’t tested and it doesn’t sound too intuitive, but it might be worth a shot: [RELEASE] Radio Add-on (rad.io, radio.de, radio.fr, radio.pt, radio.es) Music Plugin
Do you know the URL that you would put into something like vlc?
if so, create a .m3u file and include it:
#EXTM3U
#EXTINF:-1 tvg-name=“” group-title=“” tvg-logo=“”,title for your stream
http://some.domain.com/some/file/path.m3u8
#EXTINF:-1 tvg-name=“” group-title=“” tvg-logo=“”,another stream
http://some.other-domain.com/some/other/file/path.mp3
Then navigate to it on the filesystem, and add it to your favorites.
I think that Bassdrive is on SHOUTcast … so try installing that add on.
OK thanks, saving and opening the m3u file, i will try that.
