Hello!
I have a quick question regarding the Vertical Shift option in Video settings. I have a 16:9 projector screen, with a projector that does not provide enough vertical lens shift for me to shift the image so that I can then mask the top of the image to achieve a scope aspect ratio.
When I found the Vertical Shift option, I figured I could use that to shift the video instead of the projected image itself. But when I try it out on 2.40:1 movies, changing the value to -2.0 and 2.0 has no effect at all. However when I disable hardware acceleration, it suddenly starts working.
I found a couple of old threads which seemed to indicate that support for Vertical Shift using hardware acceleration had been added, so I just want to confirm if this feature is supposed to work, or not?
