Hi, just bought the official PSU for raspberry, but the error remains. Interestingly i can copy big files for some minutes, then it begins to stuck…
[May 5 10:48] scsi host1: iSCSI Initiator over TCP/IP
[ +0.031593] scsi 1:0:0:0: Direct-Access QNAP iSCSI Storage 4.0 PQ: 0 ANSI: 5
[ +0.003837] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ +0.002597] sd 1:0:0:0: [sdb] 524288000 512-byte logical blocks: (268 GB/250 G iB)
[ +0.000682] sd 1:0:0:0: [sdb] Write Protect is off
[ +0.000025] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 08
[ +0.001334] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, does n’t support DPO or FUA
[ +0.010337] sdb: sdb1
[ +0.009722] sd 1:0:0:0: [sdb] Attached SCSI disk
[ +0.328048] BTRFS: device fsid 5df90d67-6a28-4611-b85c-27f2dc8704df devid 1 tr ansid 271 /dev/sdb1
[ +4.867307] BTRFS info (device sdb1): disk space caching is enabled
[ +0.000012] BTRFS info (device sdb1): has skinny extents
[ +0.072175] BTRFS info (device sdb1): bdev /dev/sdb1 errs: wr 36, rd 0, flush 0, corrupt 0, gen 0
[ +22.875484] BTRFS info (device sdb1): the free space cache file (91297415168) is invalid, skip it
[May 5 11:00] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 56843, last ping 56472, now 57864
[ +0.000054] connection2:0: detected conn error (1022)
[May 5 11:05] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 87151, last ping 87656, now 88160
[ +0.000035] connection2:0: detected conn error (1022)
[ +22.240074] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 89361, last ping 88864, now 90384
[ +0.000069] connection2:0: detected conn error (1022)
[May 5 11:06] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 91591, last ping 91096, now 92616
[ +0.000059] connection2:0: detected conn error (1022)
[ +22.320025] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 93821, last ping 93335, now 94848
[May 5 11:07] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 96049, last ping 95560, now 97072
[ +0.000053] connection2:0: detected conn error (1022)
[ +22.240023] connection2:0: ping timeout of 5 secs expired, recv timeout 5, la st rx 98273, last ping 97788, now 99296
[ +0.000078] connection2:0: detected conn error (1022)
[ +0.001633] print_req_error: I/O error, dev sdb, sector 218190848
[ +0.000013] sd 1:0:0:0: [sdb] tag#28 UNKNOWN(0x2003) Result: hostbyte=0x0e dri verbyte=0x00
[ +0.000005] sd 1:0:0:0: [sdb] tag#27 UNKNOWN(0x2003) Result: hostbyte=0x0e dri verbyte=0x00
[ +0.000021] sd 1:0:0:0: [sdb] tag#27 CDB: opcode=0x2a 2a 00 0d 01 90 00 00 04 00 00
[ +0.000009] sd 1:0:0:0: [sdb] tag#28 CDB: opcode=0x2a 2a 00 0d 01 3c 00 00 04 00 00
[ +0.000009] print_req_error: I/O error, dev sdb, sector 218206208
[ +0.000006] print_req_error: I/O error, dev sdb, sector 218184704
[ +0.000173] sd 1:0:0:0: [sdb] tag#30 UNKNOWN(0x2003) Result: hostbyte=0x0e dri verbyte=0x00
[ +0.000005] sd 1:0:0:0: [sdb] tag#29 UNKNOWN(0x2003) Result: hostbyte=0x0e dri verbyte=0x00
[ +0.000003] sd 1:0:0:0: [sdb] tag#31 UNKNOWN(0x2003) Result: hostbyte=0x0e dri verbyte=0x00
[ +0.000008] sd 1:0:0:0: [sdb] tag#29 CDB: opcode=0x2a 2a 00 0d 01 7c 00 00 04 00 00
[ +0.000004] sd 1:0:0:0: [sdb] tag#31 CDB: opcode=0x2a 2a 00 0d 01 58 00 00 04 00 00
[ +0.000005] sd 1:0:0:0: [sdb] tag#30 CDB: opcode=0x2a 2a 00 0d 01 8c 00 00 04 00 00
[ +0.000004] print_req_error: I/O error, dev sdb, sector 218191872
[ +0.000006] print_req_error: I/O error, dev sdb, sector 218201088
[ +0.000011] print_req_error: I/O error, dev sdb, sector 218205184
[ +0.000122] sd 1:0:0:0: [sdb] tag#3 UNKNOWN(0x2003) Result: hostbyte=0x0e driv erbyte=0x00
[ +0.000004] sd 1:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x0e driv erbyte=0x00
[ +0.000003] sd 1:0:0:0: [sdb] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x0e driv erbyte=0x00
[ +0.000008] sd 1:0:0:0: [sdb] tag#0 CDB: opcode=0x2a 2a 00 0d 00 25 c8 00 04 0 0 00
[ +0.000003] sd 1:0:0:0: [sdb] tag#1 CDB: opcode=0x2a 2a 00 0d 01 9c 00 00 04 0 0 00
[ +0.000004] sd 1:0:0:0: [sdb] tag#3 CDB: opcode=0x2a 2a 00 0d 01 2c 00 00 04 0 0 00
[ +0.000004] print_req_error: I/O error, dev sdb, sector 218209280
[ +0.000007] print_req_error: I/O error, dev sdb, sector 218113480
[ +0.000005] print_req_error: I/O error, dev sdb, sector 218180608
[ +0.000113] print_req_error: I/O error, dev sdb, sector 218208256
[ +0.000004] sd 1:0:0:0: [sdb] tag#5 UNKNOWN(0x2003) Result: hostbyte=0x0e driv erbyte=0x00
[ +0.000004] sd 1:0:0:0: [sdb] tag#2 UNKNOWN(0x2003) Result: hostbyte=0x0e driv erbyte=0x00
[ +0.000007] sd 1:0:0:0: [sdb] tag#5 CDB: opcode=0x2a 2a 00 0d 01 5c 00 00 04 0 0 00
[ +0.000011] sd 1:0:0:0: [sdb] tag#2 CDB: opcode=0x2a 2a 00 0d 01 74 00 00 04 0 0 00
[ +0.000016] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 38, rd 0, flush 0, corrupt 0, gen 0
[ +0.000184] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 39, rd 0, flush 0, corrupt 0, gen 0
[ +0.001244] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 40, rd 0, flush 0, corrupt 0, gen 0
[ +0.000096] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 41, rd 0, flush 0, corrupt 0, gen 0
[ +0.000047] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 42, rd 0, flush 0, corrupt 0, gen 0
[ +0.001195] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 43, rd 0, flush 0, corrupt 0, gen 0
[ +0.000140] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 44, rd 0, flush 0, corrupt 0, gen 0
[ +0.000059] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 45, rd 0, flush 0, corrupt 0, gen 0
[ +0.001123] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 46, rd 0, flush 0, corrupt 0, gen 0
[ +0.000163] BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 47, rd 0, flush 0, corrupt 0, gen 0
[ +22.233521] connection2:0: ping timeout of 5 secs expired, recv timeout 5, last rx 100497, last ping 100012, now 101520
