log snippet
2020-03-21 17:08:11.714 T:4068425728 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2020-03-21 17:08:11.844 T:4026528480 NOTICE: Found 1 Lists of Devices
2020-03-21 17:08:11.844 T:4026528480 NOTICE: Enumerated ALSA devices:
2020-03-21 17:08:11.844 T:4026528480 NOTICE: Device 1
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_deviceName : default
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_displayName : Default (AML-M8AUDIO Analog)
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_displayNameExtra: PCM
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_channels : FL, FR, UNKNOWN1, LFE, FC, BC, BL, BR, BLOC, BROC
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2020-03-21 17:08:11.844 T:4026528480 NOTICE: m_streamTypes : No passthrough capabilities
2020-03-21 17:08:11.844 T:4026528480 NOTICE: Device 2
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_deviceName : sysdefault:CARD=AMLM8AUDIO
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_displayName : AML-M8AUDIO
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_displayNameExtra: PCM
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_deviceType : AE_DEVTYPE_PCM
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_channels : FL, FR, UNKNOWN1, LFE, FC, BC, BL, BR, BLOC, BROC
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_streamTypes : No passthrough capabilities
2020-03-21 17:08:11.845 T:4026528480 NOTICE: Device 3
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_deviceName : hdmi:CARD=AMLM8AUDIO,DEV=0
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_displayNameExtra: HDMI
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2020-03-21 17:08:11.845 T:4026528480 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2020-03-21 17:08:11.994 T:4068425728 ERROR: GetString: error reading /home/osmc/.kodi/userdata/disp_cap
2020-03-21 17:08:11.994 T:4068425728 ERROR: GetString: error reading /sys/class/amhdmitx/amhdmitx0/vesa_cap
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Current display setting is 0192001080060.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Current output resolution is 0128000720060.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 0 00480060.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940060 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 2 00576050.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 3 00720050.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 4 00720060.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940060 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 24.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 6 01080024.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 23.976025 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 25.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 8 01080025.00000pstd
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 30.000000 Hz
2020-03-21 17:08:11.995 T:4068425728 NOTICE: Fallback resolution at 16 + 9 01080030.00000pstd
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 29.970030 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 50.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Fallback resolution at 16 + 11 01080050.00000istd
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Fallback resolution at 16 + 12 01080050.00000pstd
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 60.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Fallback resolution at 16 + 13 01080060.00000istd
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080i @ 59.940060 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Current resolution setting found at 16 + 15
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940060 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 24.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 23.976025 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 25.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 30.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 29.970030 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 50.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Previous line repeats 1 times.
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 60.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 3840 x 2160 @ 59.940060 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 4096 x 2160 @ 24.000000 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found resolution 1920 x 1080 with 4096 x 2160 @ 23.976025 Hz
2020-03-21 17:08:11.996 T:4068425728 NOTICE: Found best resolution 0192001080060.00000pstd at 31, setting to RES_DESKTOP at 16
2020-03-21 17:08:12.007 T:4068425728 NOTICE: EGL_VERSION = 1.4 Linux-r5p1-01rel0
2020-03-21 17:08:12.007 T:4068425728 NOTICE: EGL_VENDOR = ARM
2020-03-21 17:08:12.007 T:4068425728 NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context
2020-03-21 17:08:12.007 T:4068425728 NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2020-03-21 17:08:12.009 T:4068425728 NOTICE: Checking resolution 16
2020-03-21 17:08:12.224 T:4068425728 NOTICE: GL_VENDOR = ARM
2020-03-21 17:08:12.224 T:4068425728 NOTICE: GL_RENDERER = Mali-450 MP
2020-03-21 17:08:12.224 T:4068425728 NOTICE: GL_VERSION = OpenGL ES 2.0
2020-03-21 17:08:12.224 T:4068425728 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2020-03-21 17:08:12.224 T:4068425728 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
2020-03-21 17:08:12.962 T:4068425728 NOTICE: WaitForNet: Waiting for a network interface to come up (Timeout: 1 s)
2020-03-21 17:08:13.163 T:4068425728 NOTICE: WaitForNet: A network interface is up after waiting 200 ms
2020-03-21 17:08:13.165 T:3965891296 NOTICE: Running database version Addons27
2020-03-21 17:08:13.167 T:3965891296 NOTICE: Running database version ViewModes6
2020-03-21 17:08:13.170 T:3965891296 NOTICE: Running database version Textures13
2020-03-21 17:08:13.177 T:3965891296 NOTICE: Running database version MyMusic72
2020-03-21 17:08:13.187 T:3965891296 NOTICE: Running database version MyVideos116
2020-03-21 17:08:13.190 T:3965891296 NOTICE: Running database version TV32
2020-03-21 17:08:13.192 T:3965891296 NOTICE: Running database version Epg12
2020-03-21 17:08:13.192 T:4068425728 NOTICE: start dvd mediatype detection
2020-03-21 17:08:13.266 T:4068425728 NOTICE: load skin from: /home/osmc/.kodi/addons/skin.aura (version: 1.0.2)
2020-03-21 17:08:13.952 T:4068425728 WARNING: CApplication::Initialize - startup.xml taints init process
2020-03-21 17:08:13.974 T:4068425728 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
2020-03-21 17:08:14.048 T:4068425728 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2020-03-21 17:08:14.049 T:4068425728 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2020-03-21 17:08:14.061 T:4068425728 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2020-03-21 17:08:14.065 T:4068425728 NOTICE: Loaded playercorefactory configuration
2020-03-21 17:08:14.065 T:4068425728 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2020-03-21 17:08:14.066 T:4068425728 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2020-03-21 17:08:14.128 T:4068425728 NOTICE: initialize done
2020-03-21 17:08:14.128 T:4068425728 NOTICE: Running the application…
2020-03-21 17:08:14.502 T:3894399712 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
2020-03-21 17:08:14.578 T:4068425728 NOTICE: starting zeroconf publishing
2020-03-21 17:08:14.579 T:4068425728 NOTICE: CWebServer[80]: Started
2020-03-21 17:08:14.581 T:3722109664 NOTICE: ES: Starting UDP Event server on port 9777
2020-03-21 17:08:14.582 T:3722109664 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2020-03-21 17:08:16.217 T:4068425728 ERROR: Misplaced !
2020-03-21 17:08:16.217 T:4068425728 ERROR: Error parsing boolean expression string.endswith(listitem.label,!)
2020-03-21 17:08:16.815 T:3730502368 ERROR: GetDirectory - Error getting library://video/tvshows/inprogressshows.xml
2020-03-21 17:08:25.278 T:3516916448 NOTICE: Skin Helper Service → Starting WebService on port 52307
2020-03-21 17:08:25.279 T:3823084256 NOTICE: Skin Helper Service → Skin Helper Service version 1.1.24 started
2020-03-21 17:08:28.683 T:3848262368 NOTICE: PLEX.service: Delaying Plex startup by: 0 sec…
2020-03-21 17:08:28.750 T:3848262368 NOTICE: PLEX.service: ======== START PlexKodiConnect ========
2020-03-21 17:08:28.750 T:3848262368 NOTICE: PLEX.service: KODI Version: 18.5
2020-03-21 17:08:28.751 T:3848262368 NOTICE: PLEX.service: PlexKodiConnect Version: 2.11.6
2020-03-21 17:08:28.763 T:3848262368 NOTICE: PLEX.service: PKC Direct Paths: True
2020-03-21 17:08:28.775 T:3848262368 NOTICE: PLEX.service: Escape paths: False
2020-03-21 17:08:28.787 T:3848262368 NOTICE: PLEX.service: Synching Plex artwork to Kodi: True
2020-03-21 17:08:28.799 T:3848262368 NOTICE: PLEX.service: Number of sync threads: 10
2020-03-21 17:08:28.800 T:3848262368 NOTICE: PLEX.service: Playlist m3u encoding: utf-8
2020-03-21 17:08:28.801 T:3848262368 NOTICE: PLEX.service: Full sys.argv received: [‘’]
2020-03-21 17:08:28.813 T:3848262368 NOTICE: PLEX.service: Sync playlists: false
2020-03-21 17:08:28.825 T:3848262368 NOTICE: PLEX.service: Synching only specific Kodi playlists: False
2020-03-21 17:08:28.838 T:3848262368 NOTICE: PLEX.service: Kodi playlist prefix: sync_
2020-03-21 17:08:28.863 T:3848262368 NOTICE: PLEX.service: Synching only specific Plex playlists: False
2020-03-21 17:08:28.878 T:3848262368 NOTICE: PLEX.service: Play playlist prefix: sync_
2020-03-21 17:08:28.892 T:3848262368 NOTICE: PLEX.service: Db version: 2.8.0
2020-03-21 17:08:28.893 T:3848262368 NOTICE: PLEX.service: Kodi video database version: 116
2020-03-21 17:08:28.894 T:3848262368 NOTICE: PLEX.service: Kodi music database version: 72
2020-03-21 17:08:28.894 T:3848262368 NOTICE: PLEX.service: Kodi texture database version: 13
2020-03-21 17:08:29.057 T:3848262368 NOTICE: PLEX.clientinfo: Unique device Id plex_client_Id loaded: XXXXXXXXX
2020-03-21 17:08:31.207 T:4068425728 NOTICE: VideoPlayer::OpenFile: smb://192.168.1.7/Multimedia/My Videos/Movies/Parasite.2019.2160p.UHD.BluRay.X265.mkv
2020-03-21 17:08:31.207 T:3382633184 NOTICE: Creating InputStream
2020-03-21 17:08:31.375 T:3831476960 NOTICE: Skin Helper Widgets → Backgroundservice started
2020-03-21 17:08:31.800 T:3848262368 NOTICE: PLEX.kodimonitor: Kodi monitor started.
2020-03-21 17:08:31.950 T:3848262368 NOTICE: PLEX.initialsetup: Initial setup called.
2020-03-21 17:08:32.072 T:3382633184 NOTICE: Creating Demuxer
2020-03-21 17:08:32.468 T:3848262368 NOTICE: PLEX.initialsetup: Current Kodi video memory cache in bytes: 20971520
2020-03-21 17:08:32.585 T:3848262368 NOTICE: PLEX.migration: Checking whether we need to migrate something
2020-03-21 17:08:32.995 T:3848262368 NOTICE: PLEX.initialsetup: PMS is already set: http://192.168.1.7:32400. Checking now…
2020-03-21 17:08:33.165 T:3382633184 NOTICE: Opening stream: 0 source: 256
2020-03-21 17:08:33.165 T:3382633184 NOTICE: Whitelist search for: width: 3840, height: 1606, fps: 23.976, 3D: false
2020-03-21 17:08:33.167 T:3382633184 NOTICE: Display resolution ADJUST : 3840x2160 @ 23.98 - Full Screen (34) (weight: 0.000)
2020-03-21 17:08:33.219 T:4068425728 NOTICE: VideoPlayer: OnLostDisplay received
2020-03-21 17:08:33.219 T:4068425728 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2020-03-21 17:08:33.220 T:4068425728 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
2020-03-21 17:08:33.505 T:4068425728 NOTICE: VideoPlayer: OnResetDisplay received
2020-03-21 17:08:33.505 T:4068425728 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2020-03-21 17:08:33.505 T:4068425728 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
2020-03-21 17:08:33.554 T:3382633184 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 173
2020-03-21 17:08:33.570 T:3382633184 NOTICE: Creating video thread
2020-03-21 17:08:33.571 T:3349144288 NOTICE: running thread: video_thread
2020-03-21 17:08:33.571 T:3382633184 NOTICE: Opening stream: 1 source: 256
2020-03-21 17:08:33.571 T:3382633184 NOTICE: Finding audio codec for: 86060
2020-03-21 17:08:33.572 T:3382633184 NOTICE: Creating audio thread
2020-03-21 17:08:33.572 T:3307180768 NOTICE: running thread: CVideoPlayerAudio::Process()
2020-03-21 17:08:33.572 T:3382633184 NOTICE: Opening stream: 4 source: 256
2020-03-21 17:08:33.583 T:3307180768 NOTICE: Creating audio stream (codec id: 86060, channels: 8, sample rate: 48000, pass-through)
2020-03-21 17:08:33.596 T:3307180768 ERROR: CAEStreamInfo::GetDuration - invalid stream type
2020-03-21 17:08:34.192 T:3848262368 ERROR: Previous line repeats 1 times.
2020-03-21 17:08:34.192 T:3848262368 NOTICE: PLEX.initialsetup: Using PMS http://192.168.1.7:32400 with machineIdentifier XXXXXXXXXXX
2020-03-21 17:08:34.226 T:4068425728 NOTICE: Whitelist search for: width: 3840, height: 1606, fps: 23.976, 3D: false
2020-03-21 17:08:34.226 T:4068425728 NOTICE: Display resolution ADJUST : 3840x2160 @ 23.98 - Full Screen (34) (weight: -0.000)
2020-03-21 17:08:34.694 T:3848262368 NOTICE: PLEX.plex_companion: ----===## Starting PlexCompanion ##===----
2020-03-21 17:08:34.761 T:3332358880 NOTICE: PLEX.service: Server is online and ready
2020-03-21 17:08:34.831 T:2983080672 NOTICE: PLEX.service: Authenticating user
2020-03-21 17:08:34.831 T:2983080672 NOTICE: PLEX.service: Trying to authenticate with old settings
2020-03-21 17:08:34.860 T:2983080672 NOTICE: PLEX.service: Successfully authenticated using old settings
2020-03-21 17:08:34.933 T:2999866080 NOTICE: PLEX.websocket_client: ----===## Starting PMS_Websocket ##===----
2020-03-21 17:08:34.934 T:3672109792 NOTICE: PLEX.sync: —===### Starting Sync Thread ###===—
2020-03-21 17:08:34.990 T:2974687968 NOTICE: PLEX.playqueue: ----===## Starting PlayqueueMonitor ##===----
2020-03-21 17:08:34.992 T:3623965408 NOTICE: PLEX.plexgdm: Discovery starting up
2020-03-21 17:08:34.993 T:3008258784 NOTICE: PLEX.websocket_client: ----===## Starting Alexa_Websocket ##===----
2020-03-21 17:08:35.012 T:3623965408 NOTICE: PLEX.plexgdm: Registration starting up
2020-03-21 17:08:35.303 T:3672109792 NOTICE: PLEX.utils: Init DBs done
2020-03-21 17:08:35.304 T:3672109792 NOTICE: PLEX.sync: Doing initial sync on Kodi startup
2020-03-21 17:08:35.358 T:3672109792 NOTICE: PLEX.sync.sections: Starting synching sections from the PMS
2020-03-21 17:08:35.534 T:3672109792 NOTICE: PLEX.sync.sections: Done synching sections from the PMS: [{‘index’: 0, ‘name’: ‘Local Content’, ‘section_id’: 4, ‘section_type’: ‘movie’, ‘sync_to_kodi’: False, ‘last_sync’: 0}, {‘index’: 1, ‘name’: ‘Movies’, ‘section_id’: 1, ‘section_type’: ‘movie’, ‘sync_to_kodi’: True, ‘last_sync’: 1582416775}, {‘index’: 2, ‘name’: ‘TV Shows’, ‘section_id’: 2, ‘section_type’: ‘show’, ‘sync_to_kodi’: True, ‘last_sync’: 1582416775}]
2020-03-21 17:08:35.541 T:2606047968 NOTICE: PLEX.sync.full_sync: User chose to not sync section {‘index’: 0, ‘name’: ‘Local Content’, ‘section_id’: 4, ‘section_type’: ‘movie’, ‘sync_to_kodi’: False, ‘last_sync’: 0}
2020-03-21 17:08:35.765 T:3672109792 NOTICE: PLEX.utils: It took 0:00:00.226291 to run the function process_new_and_changed_items
2020-03-21 17:08:35.801 T:3332358880 NOTICE: PLEX.sync.full_sync: User chose to not sync section {‘index’: 0, ‘name’: ‘Local Content’, ‘section_id’: 4, ‘section_type’: ‘movie’, ‘sync_to_kodi’: False, ‘last_sync’: 0}
2020-03-21 17:08:35.869 T:3730502368 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
2020-03-21 17:08:35.880 T:3965891296 NOTICE: VideoInfoScanner: Starting scan …
2020-03-21 17:08:35.885 T:3965891296 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
2020-03-21 17:08:37.018 T:3672109792 NOTICE: PLEX.utils: It took 0:00:01.217226 to run the function processing_loop_playstates
2020-03-21 17:08:37.134 T:3672109792 NOTICE: PLEX.utils: It took 0:00:01.776029 to run the function _run
2020-03-21 17:08:37.135 T:3672109792 NOTICE: PLEX.sync: Done initial sync on Kodi startup
2020-03-21 17:08:37.151 T:3672109792 NOTICE: PLEX.sync: Start downloading additional fanart with refresh False
2020-03-21 17:08:37.152 T:2505335520 NOTICE: PLEX.sync.fanart: Starting FanartThread
2020-03-21 17:08:37.187 T:2513728224 NOTICE: PLEX.artwork: —===### Starting ImageCachingThread ###===—
2020-03-21 17:08:37.197 T:2505335520 NOTICE: PLEX.sync.fanart: FanartThread finished: True
2020-03-21 17:08:37.226 T:3713716960 NOTICE: VideoInfoScanner: Starting scan …
2020-03-21 17:08:37.226 T:3663717088 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
2020-03-21 17:08:37.301 T:3713716960 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
2020-03-21 17:08:37.324 T:2513728224 NOTICE: PLEX.artwork: —===### Stopped ImageCachingThread ###===—
2020-03-21 17:17:52.403 T:3307180768 NOTICE: CVideoPlayerAudio::Process - stream stalled pts:557.759 clock:557.941
2020-03-21 17:17:56.795 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 292839, probably corrupted
2020-03-21 17:18:39.494 T:3349144288 ERROR: Previous line repeats 20059 times.
2020-03-21 17:18:39.494 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 200982, probably corrupted
2020-03-21 17:18:39.999 T:3349144288 ERROR: Previous line repeats 334 times.
2020-03-21 17:18:39.999 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 207284, probably corrupted
2020-03-21 17:18:40.012 T:3349144288 ERROR: Previous line repeats 1 times.
2020-03-21 17:18:40.012 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 531727, probably corrupted
2020-03-21 17:18:41.120 T:4068425728 ERROR: Previous line repeats 498 times.
2020-03-21 17:18:41.120 T:4068425728 NOTICE: CVideoPlayer::CloseFile()
2020-03-21 17:18:41.124 T:4068425728 NOTICE: VideoPlayer: waiting for threads to exit
2020-03-21 17:18:41.126 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 531727, probably corrupted
2020-03-21 17:18:41.127 T:3382633184 NOTICE: CVideoPlayer::OnExit()
2020-03-21 17:18:41.127 T:3382633184 NOTICE: Closing stream player 1
2020-03-21 17:18:41.127 T:3382633184 NOTICE: Waiting for audio thread to exit
2020-03-21 17:18:41.127 T:3307180768 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2020-03-21 17:18:41.127 T:3307180768 NOTICE: thread end: CVideoPlayerAudio::OnExit()
2020-03-21 17:18:41.128 T:3382633184 NOTICE: Closing audio device
2020-03-21 17:18:41.134 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 531727, probably corrupted
2020-03-21 17:18:41.176 T:3349144288 ERROR: Previous line repeats 2 times.
2020-03-21 17:18:41.176 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 318738, probably corrupted
2020-03-21 17:18:41.189 T:3382633184 ERROR: Previous line repeats 7 times.
2020-03-21 17:18:41.189 T:3382633184 NOTICE: Deleting audio codec
2020-03-21 17:18:41.189 T:3349144288 ERROR: CAMLCodec::AddData: packet to big: 318738, probably corrupted
2020-03-21 17:18:41.189 T:3382633184 NOTICE: Closing stream player 2
2020-03-21 17:18:41.189 T:3382633184 NOTICE: waiting for video thread to exit
2020-03-21 17:18:41.189 T:3349144288 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2020-03-21 17:18:41.190 T:3349144288 NOTICE: thread end: video_thread
2020-03-21 17:18:41.191 T:3382633184 NOTICE: deleting video codec
2020-03-21 17:18:41.326 T:3382633184 NOTICE: Closing stream player 3
2020-03-21 17:18:41.477 T:4068425728 NOTICE: VideoPlayer: finished waiting
2020-03-21 17:18:41.478 T:4068425728 NOTICE: CVideoPlayer::CloseFile()
2020-03-21 17:18:41.478 T:4068425728 NOTICE: VideoPlayer: waiting for threads to exit
2020-03-21 17:18:41.478 T:4068425728 NOTICE: VideoPlayer: finished waiting
2020-03-21 17:18:41.901 T:3382633184 ERROR: GetDirectory - Error getting library://video/tvshows/inprogressshows.xml
2020-03-21 17:18:42.894 T:3713716960 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.white/30.png
2020-03-21 17:20:17.396 T:4068425728 NOTICE: Samba is idle. Closing the remaining connections
---------------------- Kodi Log END --------------- HyhIT4UP
