I’ve just purchased the Vero 4K+ from your website and plugged it today.
I tried to plug in two working hard drives (not simultaneously) and each time I have an issue :
The 3.5 HD (self powered) is not recognized at all
The 2.5 HD (not self powered) is lowly recognized but makes regularly a noise indicating that it restarts every few seconds and I can’t launch any video.
Thanks for your reply.
I did not try to plug the two hard drives simultaneously. The self-powered one was the only one plugged in and was not recognized.
reproduce the issue
Here we go. I followed the instructions and here are the results:
For the 2.5HDD (not self-powered): the HDD was recognised after a long time and playing, pausing stopping the video took like 10 seconds each time (navigating in the folders is tedious; but the HD is still running and clicking like it was rebooting). I precise that it works fine under OSMC & RPI3.
The logs are here : https://paste.osmc.tv/timitubuva
I can access ELEMENTS but it takes time to mount and navigation within the folders is very slow. I did not have any issue with the very same HDD on Raspberry Pi 3
RPi3 on Kodi 18 (I think) everything was working fine
RPI3 on Kodi 19 (after recent major update) - stutter and unsync on some videos but HDD working fine (mount, access and navigation) except on H264 or H265 videos but it’s on the RPI3, not the HDD (reason why I bought the Vero).
