Thanks Sam i have now uploaded the file for you to test.
Interestingly while on WiFi I tested a lower bitrate file ~30mbps and that struggled to play over WiFi with buffering issues.
When i switched back to a wired 100mbps connection that file played fine and even more surprisingly the camcorder 100mbps files do play after pausing them for a couple of secs despite the connection in theory being slower than WiFi which was getting higher throughput.
I’ve never been a fan of WiFi and always seen it to be flaky much prefer the good old fashioned hard wire connection
Let me know how you get on testing the file on the Vero 4k+ and if it plays without buffering then i will buy a Vero 4k+.
Hi Sam just wondering if you have had chance to test the file yet? I was holding off buying the 4k+ until you confirmed the file played smoothly on the 4k+. Unfortunately I see it has gone back to full price now.
Sorry for the late reply. I’m not sure how I missed this one.
I’ve had a chance to test the clip. This played without issue on Vero 4K + using GigE.
Send me a ping to support@osmc.tv or PM and we will let you have this for £99 as you did express interest prior to this. Be aware that we do have some delays at this point.
Hi Sam,
No need for apologies I know how busy you are and I’m very grateful for your help.
That’s good news about it working on the 4k+ I have sent you a PM.
