Upgraded OSMC this morning to Kodi v19 on my Pi 3B+ - all generally OK, aside from an odd issue with CEC.
Some of the buttons (pause/play etc) from the remote no longer work. Other buttons (such as navigation/select) work fine through CEC.
Everything was fine prior to upgrading this morning.
Troubleshooting steps so far: check logs, disable/enable CEC in Kodi & TV, power off everything & unplug for 15 minutes and power back on.
Quick output from kodi.log (grepping just for HandleKey logs)
osmc@osmc:~/.kodi/temp$ tail -f kodi.log | grep Handle
2021-08-08 15:19:42.156 T:478 DEBUG : HandleKey: 167 (0xa7, obc88) pressed, action is Down
2021-08-08 15:19:42.940 T:478 DEBUG : HandleKey: 166 (0xa6, obc89) pressed, action is Up
2021-08-08 15:19:44.056 T:478 DEBUG : HandleKey: 166 (0xa6, obc89) pressed, action is Up
Logs uploaded to https://paste.osmc.tv/UGUNELIMIM (though it shows "Document Not Found)
Log contents;
Rebooted
Navigated using CEC
Started playing something
Attempted to pause (doesn’t show in log)
Stopped via on screen options
Uploaded log
Any thoughts? Understand this isn’t a huge issue in the grand scheme of things.
