Try setting Output configuration to best match, rather than optimised.
Thanks Tom.
Thanks Tom.
Hi Tom,
I tried, but it doesnt help. “pass-through output device” option is still disabled, set to HDMI and cannot be changed to my HiFiBerry Digital.
Jan
I have the same problem.
I am using OSMC on RPi with HiFBerry Digi board in order to pass-through the audio by SPDIF-Out to my Receiver. Everything has worked great for years, until this last update. Now there is no multichannel sound in SPDIF-out.
Exploring the sound settings in OSMC I discovered that pass-through is now directed to HDMI instead of HifiBerry/SPDIF. Also, my TV is alerting that it detects incompatible sound in HDMI. Unfortunately, the “pass-through output device: HDMI” option is disabled and cannot be changed:-(
Resetting advised by wbeard52 doesn’t work for me.
My log: https://paste.osmc.tv/ebejijowoy
Thanks for any advice!
I’ve Moved your posts to a new topic, as I’m not conviced it is the same issue as the OP (sorry messed up post order, been a long day).
If you disable passthrough (for testing), are you then able to change output device?
Thanks Tom.
OK.
When I disable “pass-through” then all the options in this category are disabled as well, including “pass-through output device: HDMI”.
(please, correct the typo in the title, " HiFiBerry" instead of “HiFBerry”, so other people can more easily google this thread)
Jan
Done (sorry).
Please try the following, you will need to access the command-line:
mv .kodi kodi.back
If you then able to select the HiFiBerry, then all I can suggest is restore settings and addons one at time, until the cause of the issue is found.
If that doesn’t help, you can restore all your settings:
mv kodi.back .kodi
And we will investigate further.
Thanks Tom.
…thanks, first and the last commands works, but I cannot perform the second command:
“mv: cannot stat ‘.kodi’: No such file or directory”
I really cant see directory .kodi anywhere in the file structure…
Jan
Try this:
cd /home/osmc
mv .kodi kodi.back
Edit:
‘.kodi’ isn’t right it should be .kodi or ‘.kodi’ or even “.kodi”; there is a difference between ’ ( apostrophe) & ‘ (backtick).
Thanks Tom.
If you don’t have a .kodi directory, and you didn’t already move it then you have a serious problem. If you restart Kodi (mediacenter) it should create a new .kodi directory. If it doesn’t then you most likely have a failing SD card.
…it seems that I have moved it in one of the previous attempts. After restarting the media center, my settings were gone. I checked the audio-ouput settings, put there back the HifiBerry, but in pass-through section, there is still the same problem “pass-through output device:" is set to HDMI and is disabled.
…I really appreciate your help, thanks for your time.
Jan
… downgrading the OSMC to the previous version seems to be the only solution for me so far.
Jan
Hi Dritst, I was investigating why my audio was suddently always in stereo and it look like I have the same problem as you, I can’t select anything else than hdmi in the passthrough settings. Did you find a solution other than a downgrade? I confirm that a fresh .kodi folder do not resolve this problem. Thanks.
Hello! Unfortunately, I still dont know the solution. I have downgraded to the previous version and I am not installing the updates from that time. Only this way HifiBerry/SPDIF multichannel works for me.
Thanks for your feedback. For now my workaround is LibreElec.
Thanks for the hint! I will give it a chance.
Could someone with this problem please post debug logs as the February one has timed out.
Hopefully the issue is now addressed with the following commit:
/etc/apt/sources.list
I also recommend you edit /etc/apt/sources.list
again and remove the line that you added after updating. This will return you to the normal update channel.
