tried to playback The Adjustment Bureau, it plays kinda in slow motion, if i skip chapters then audio is way out of sync
General
Unique ID : 96735075259482635205035900975126985485 (0x48C67F7092B6142867C533CA017CBB0D)
Complete name : /Volumes/Video/Movies/The Adjustment Bureau (2011)-1080p/The Adjustment Bureau (2011)_DTSHD-MA.Blu-ray.mkv
Format : Matroska
Format version : Version 2
File size : 25.5 GiB
Duration : 1 h 45 min
Overall bit rate : 34.5 Mb/s
Movie name : The Adjustment Bureau
Encoded date : UTC 2013-08-18 14:38:25
Writing application : MakeMKV v1.8.4 darwin(x86-release)
Writing library : libmakemkv v1.8.4 (1.2.0/1.1.0) darwin(x86-release)
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Language : English
Default : No
Forced : No
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Title : Lossless
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:06:37.772 : en:Chapter 02
00:14:17.314 : en:Chapter 03
00:20:58.215 : en:Chapter 04
00:28:35.547 : en:Chapter 05
00:31:11.494 : en:Chapter 06
00:35:22.078 : en:Chapter 07
00:38:58.711 : en:Chapter 08
00:43:07.001 : en:Chapter 09
00:51:35.050 : en:Chapter 10
00:58:33.009 : en:Chapter 11
01:02:14.605 : en:Chapter 12
01:07:32.089 : en:Chapter 13
01:12:00.649 : en:Chapter 14
01:14:13.449 : en:Chapter 15
01:19:47.574 : en:Chapter 16
01:24:11.504 : en:Chapter 17
01:30:00.603 : en:Chapter 18
01:35:53.497 : en:Chapter 19
01:38:54.470 : en:Chapter 20
