I have been using Vero 4K+ for over a year, I’m very happy with it but I have been experiencing some issues playing some 4K HDR files, coincidendly I’ve noticed it after the lastest Kodi update (two week ago, maybe?). I uploaded this video showing what the issue looks like, all the 4K files that the Vero can’t play anymore look like this mind you.
For instance, The.Revenant.2015.2160p.UHD.BluRay.X265 plays fines, this is the file data:
Matroska: 17.9 GiB, 2 h 36 min
1 Video stream: HEVC
1 Audio stream: DTS XLL
14 Text streams:
1 Menu stream
Duration: 2 h 36 min
Overall bit rate mode: Variable
Overall bit rate: 16.4 Mb/s
Encoded date: UTC 2010-02-22 21:41:29
Writing application: no_variable_data
Video: 3840*1608 at 23.976 FPS,
HVEC (Main 10@L5.1@High), HDR10
BUT this, Minions.The.Rise.of.Gru.2022.2160p.UHD.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos does not:
Matroska: 16.2 GiB, 1 h 27 min
3 Audio streams: MLP FBA 16-ch / DTS XLL / AC-3
5 Text streams: UTF-8 / UTF-8 / PGS / PGS / PGS
Duration: 1 h 27 min
Overall bit rate: 26.6 Mb/s
Encoded date: UTC 2022-09-02 05:50:44
Video: 18.6 Mb/s, 3840*1608 at 23.976 FPS,
HEVC (Main 10@L5.1@High), HDR10
What could it be? I play my movies from a HDD connected to a Macbook using smb, the Vero 4K is connected via ethernet cable. I’m inclined to think the issue here is the overall bitrate but why suddenly? This might sound dumb, but should I try buying a different HDMI cable, ethernet cables? I’m pretty new at this. Any help will be much appreciated.
