January update unstable?
Got errors finally!!!
Dmesg -w output during playback.
After that I can’t do anything in osmc.
[ 1855.309866] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1589890471
[ 1855.310010] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1935779610
[ 1855.310118] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-57388942
[ 1855.310237] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-373307712
[ 1855.310527] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1023850825
[ 1855.310709] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-157113843
[ 1855.310959] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1733112373
[ 1855.312609] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1947437191
[ 1855.312795] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-2097529194
[ 1855.323117] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1029684075
[ 1855.594694] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1788478745
[ 1856.167640] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1471929634
[ 1856.319154] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1531692683
[ 1864.111000] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-1029684075
[ 1867.477138] vmscan: shrink_slab: super_cache_scan+0x0/0x1cc negative objects to delete nr=-189780176
@sam_nazarko - can I downgrade to kernel 4.3 and have Kodi16 installed same time?
Do you have any idea how to get rid of this problem?
Happy to say that the 4.4.3 kernel released with the March update has solved all the problems this end.
Thank you!
pdm
Oops. Spoke too soon.
USB Hard drive reading and writing no longer hangs.
However, pausing replay on playing a program for more than about 20-30 minutes froze the screen solid with only killing the kodi process allowing it to go again.
Will investigate re-producibility.
