I am experiencing some judder or stutter on a 1080p file. If I show info during playback I am not seeing framedrops/skips strangely. Especially in panning shots its very much “not fluent”, but also people walking seem to have issues with their pace.
Logfile (rebooted twice and uploaded via OSMC menu): https://paste.osmc.tv/hutimibope
- Adjust display refresh rate is set to: on start stop
- I tried Sync playback to display, doesn’t help (my default is off for passthrough audio)
- I tried disabling audio passthrough, doesn’t help
- file plays fine on my laptop and on kodi on a “mi box s”
- it is not happening on all files, just this tv show and another tv show I have
Other:
With info enabled I see no drops or skips at all. I do see a negative value for VsyncOff of more than -10 (eg. -16,7, fluctuating).
I also replaced my HDMI cable recently due to another issue. 4K is playing fine now and I assume this file is not heavy enough to cause issues with this HDMI cable?
I tried to send a part of the file to a friend to see if he can play it. I used mkvtoolnix to chop the file into 100 MB sizes and strangely those small files play fine which really puzzles me - what could explain that? perhaps there lies a clue to the solution.
Any clues on what I can try to solve are appreciated.
file specs
General
Unique ID : 178002605302482970644697152665291275165 (0x85EA0E059C1EACFB42E785667CB73B9D)
Complete name : U:\Series\Those Who Kill\Season 01\Den.som.draeber.s01e05 s01e06.Danish.1080p.Web-dl.DD5.1.x264-NDF.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 2.47 GiB
Duration : 1 h 25 min
Overall bit rate : 4 126 kb/s
Encoded date : UTC 2021-10-22 11:43:48
Writing application : mkvmerge v62.0.0 (‘Apollo’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference fra : 3 frames
Format settings, GOP : M=3, N=50
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 3 740 kb/s
Maximum bit rate : 7 200 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.072
Stream size : 2.24 GiB (91%)
Title : Nordicflix
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 235 MiB (9%)
Title : 5.1
Language : Danish
Service kind : Complete Main
Default : Yes
Forced : No
