My July update on Pi3 failed and tried running the manual update which won’t run either. Any possible solutions please?
Well to propose a solution we first would need to see some logs (at least the APT log).
On the other hand I would suggest to try a upgrade from the command line.
To see how to upload logs check the below URL and also how to access command line if you want to do the upgrade there.
