Just updated to 5/2 and get sad face when trying to play movie
Hey everybody,
just a quick heads up - I had another sad face yesterday after quickly zapping through some TV channels. The movies and shows I tried afterwards played without hiccups.
I’ll try to produce another log file in case I see the dreaded blue fella again.
cheers
Anthrax
Update again – doesn’t look like you picked up any packages.
This pertains to what is happening to the hissingshark hyperion.ng I have installed.
Video plays fine from any source, the second I start hyperion.ng I get the sad face and a reboot. Video will not play with hyperion.ng running now. It was working so well for me lately until today’s update.
That sounds a little bit different to the issues reported here.
Could you send me a log when this happens?
Not working for me again - definitely to do with hyperion/hyperion.ng on my side :frowning:
and this was working so well since christmas.
I’ll provide logs and might rebuild from scratch.
cheers
Anthrax
@nbraunstein
You reported this in another thread this morning. Am I right in saying it was resolved following update to the new version?
Hi, I don’t know if you’ve seen yet but I’ve replied to your query on the Hyperion Github. Just to avoid an unresolved issue floating on the forum I shall paraphrase here:
The June update brings in the underlying changes needed to fix the a/v sync issue with Hyperion.ng, so then you just need to update Hyperion.ng from my installer to get the other half of the fix. I couldn’t update Hyperion.ng in my installer before hand, because without the kernel updates to go with it that breaks AML grabbing altogether!
Update instructions here! I hope that works for you as it has for others on these threads.
Hi @hissingshark,
thanx for letting me know - I knew you guys were on it :wink:
Holy hissingsharknado!
Anthrax
Correct. Has been resolved.
I’m curious if I could skip the installer and go straight from GitHub?
I’ve done the recent update and one particular file gives me a sad face. After about the 6th time of trying it worked. Then I stopped it and the same thing happened again but worked after the 4th time. Weird. Doesn’t do it on other files. I’ve tested it on the VLC media player on the PC and it’s ok. 4K MKV. Odd.
Does this occur with a small sample of the file / a remux?
I reinstalled everything today including hyperion.ng with the needed argument after the installer. Seems to be working fine so far. Haven’t experienced many A/V sync issues either. Noticed the network takes much longer to connect after reboots or sending a reboot command via SSH sometimes takes upwards of 30 seconds. I think it’s all Hyperion.ng related.
As I have just responded in the regular Hyperion thread, no arguments are needed. That I think is why you are still using the old version, hence the A/V sync issues.
Anyone updating can just follow the update instructions. It’s all there - easy as :pie:.
Oh I’ve done a few fresh installs since than. My A/V sync issues are most likely related to PlexKodiConnect.
Hyperion.ng will not start using the feature in the script app by the way. It works for turning the lights off when the screensaver is enabled though. Just make sure it’s on Platform Capture rather than Hyperion.
