kernel introduced native encryption for the ext4 filesystem, could somebody add this option in next OSMC image, i should like use this in my raspberrypi2.
I can see this option disabled in my current kernel version:
root@osmc:/mnt/seagate/vault# grep CONFIG_EXT4_ENCRYPTION !$
grep CONFIG_EXT4_ENCRYPTION /boot/config-4.3.0-9-osmc
# CONFIG_EXT4_ENCRYPTION is not set
owncloud is a service to share files and I use it for sync my devices
I use owncloud with encriptation plugin enabled but I think it’s better use native encriptation in filesystem instead of the encriptation plugin in owncloud.
Nice! Cool!
Thank you Sam and congratulations for this Linux distribution , I played with many others and I think this is a very good choice, a very good job guys!
Moreover, I tryied modify source url in file /etc/apt/sources.list using staging.apt.osmc.tv instead of apt.osmc.tv, but I think it doesn’t work fine becasue don’t install anything after do
