Add the following line: deb http://apt.osmc.tv stretch-devel main
after a modprobe 8250 dmesg gives me:
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
also
/dev/serial0 → ttyAMA0
/dev/serial1 → ttyS0
are now there where they should be
only bluetooth is not in the network settings
and /usr/bin/hciattach /dev/ttyS0 bcm43xx 921600 noflow says:
Can’t get port settings: Input/output error
Can’t initialize device: Input/output error
