I recently updated to v19 on my Raspberry Pi 3 B, kernel 5.10.32-2-osmc.
A few days after the update I noticed that the temperature of the pi was unusually high, about 65°C instead of 55°C. The rise started at night where the device was not in use. The system journal and kodi log do not contain anything unusual at that time.
I tried to stop kodi by running sudo systemctl stop mediacenter, and it took quite a long time for the command to return. After that, I found a defunct kodi process in the process list. I tried to reboot, but even after a few minutes, the device didn’t reboot. Thus I interrupted the power supply and had a look at the logs after boot.
Extract from the system journal (more detailed logs follow):
Unable to handle kernel NULL pointer dereference at virtual address 00000280
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
PC is at vc4_hdmi_encoder_pre_crtc_configure+0x70/0x620 [vc4]
LR is at vc4_crtc_atomic_enable+0x74/0x560 [vc4]
vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Extract from the kodi log (more detailed logs follow):
2021-08-17 07:38:39.724 T:15712 INFO <general>: CAESinkALSA - Unable to open device "default" for playback
2021-08-17 07:38:39.779 T:15712 INFO <general>: CAESinkALSA - Unable to open device "jack" for playback
2021-08-17 07:38:39.933 T:15712 INFO <general>: CAESinkALSA - Unable to open device "pulse" for playback
2021-08-17 07:38:39.936 T:15712 INFO <general>: CAESinkALSA - Unable to open device "sysdefault:CARD=vc4hdmi" for playback
2021-08-17 07:38:40.103 T:15712 INFO <general>: CAESinkALSA - Unable to open device "hdmi:CARD=vc4hdmi,DEV=0" for playback
2021-08-17 07:38:40.105 T:15712 INFO <general>: CAESinkALSA - Unable to open device "usbstream:CARD=vc4hdmi" for playback
2021-08-17 07:38:40.105 T:15712 INFO <general>: Found 0 Lists of Devices
2021-08-17 07:38:40.105 T:15713 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-17 07:38:40.106 T:15713 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=vc4hdmi,DEV=0"
2021-08-17 07:38:40.113 T:15713 INFO <general>: CAESinkALSA - Unable to open device "hdmi:CARD=vc4hdmi,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00" for playback
2021-08-17 07:38:40.115 T:15713 INFO <general>: CAESinkALSA - Unable to open device "hdmi:CARD=vc4hdmi,DEV=0" for playback
2021-08-17 07:38:40.115 T:15713 ERROR <general>: CAESinkALSA::Initialize - failed to initialize device "hdmi:CARD=vc4hdmi,DEV=0"
2021-08-17 07:38:40.115 T:15713 ERROR <general>: CActiveAESink::OpenSink - no sink was returned
2021-08-17 07:38:40.115 T:15712 ERROR <general>: ActiveAE::InitSink - returned error
For me it looks like a kernel oops caused by a HDMI related driver problem. All I found about this on the web is a thread in the raspberry pi forums concerning the kernel update to v5.10 and a Kernel Patch for 5.13.3-rc1.
I don’t expect anyone to help out on this issue, but at least I want to share this information with the community.
System journal
Aug 17 07:34:15 raspberry kernel: 8<--- cut here ---
Aug 17 07:34:15 raspberry kernel: Unable to handle kernel NULL pointer dereference at virtual address 00000280
Aug 17 07:34:18 raspberry kernel: pgd = 3249ce56
Aug 17 07:34:18 raspberry kernel: [00000280] *pgd=00000000
Aug 17 07:34:18 raspberry kernel: Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Aug 17 07:34:19 raspberry kernel: Modules linked in: xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype bridge 8021q garp stp llc cmac iptable_nat
Aug 17 07:34:19 raspberry kernel: CPU: 2 PID: 25077 Comm: kodi.bin Tainted: G WC 5.10.32-2-osmc #1
Aug 17 07:34:19 raspberry kernel: Hardware name: BCM2835
Aug 17 07:34:19 raspberry kernel: PC is at vc4_hdmi_encoder_pre_crtc_configure+0x70/0x620 [vc4]
Aug 17 07:34:19 raspberry kernel: LR is at vc4_crtc_atomic_enable+0x74/0x560 [vc4]
Aug 17 07:34:19 raspberry kernel: pc : [<7f4f0248>] lr : [<7f4d992c>] psr: 680b0013
Aug 17 07:34:19 raspberry kernel: sp : 88f31c30 ip : 88f31c58 fp : 88f31c54
Aug 17 07:34:19 raspberry kernel: r10: 83120800 r9 : 00000000 r8 : 7f5010b0
Aug 17 07:34:19 raspberry kernel: r7 : 83121284 r6 : 84431040 r5 : 83121284 r4 : 00000000
Aug 17 07:34:19 raspberry kernel: r3 : 00000000 r2 : 00000003 r1 : 00000004 r0 : 81ac0810
Aug 17 07:34:19 raspberry kernel: Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Aug 17 07:34:19 raspberry kernel: Control: 10c5383d Table: 0568806a DAC: 00000055
Aug 17 07:34:19 raspberry kernel: Process kodi.bin (pid: 25077, stack limit = 0x1afd5632)
Aug 17 07:34:19 raspberry kernel: Stack: (0x88f31c30 to 0x88f32000)
Aug 17 07:34:19 raspberry kernel: 1c20: 84431040 87833c00 84431040 83121284
Aug 17 07:34:19 raspberry kernel: 1c40: 7f5010b0 00000000 88f31ca4 88f31c58 7f4d992c 7f4f01e4 88f31c9c 88f31c68
Aug 17 07:34:19 raspberry kernel: 1c60: 7f4f6340 7f4f4fc0 847e6200 00000001 00000004 87833c00 00000018 00000003
Aug 17 07:34:19 raspberry kernel: 1c80: 87833c00 84431040 7f4bc028 7f5010b0 00000000 83120800 88f31cd4 88f31ca8
Aug 17 07:34:19 raspberry kernel: 1ca0: 7f4a8e40 7f4d98c4 00000004 00000000 87833c00 83120800 83c97840 83120ce8
Aug 17 07:34:20 raspberry kernel: 1cc0: 00000000 83120800 88f31d04 88f31cd8 7f4e24f4 7f4a8c24 00000001 87833c00
Aug 17 07:34:20 raspberry kernel: 1ce0: 83120800 00000000 00000000 83120ce8 00000000 83120800 88f31d2c 88f31d08
Aug 17 07:34:20 raspberry kernel: 1d00: 7f4e2b40 7f4e2348 00000000 87833c00 83120800 88f31d60 830bd240 82597af0
Aug 17 07:34:20 raspberry kernel: 1d20: 88f31d4c 88f31d30 7f3f6150 7f4e29c8 87833c00 831209c0 00000001 88f31d60
Aug 17 07:34:20 raspberry kernel: 1d40: 88f31db4 88f31d50 7f410824 7f3f6108 81205008 00000000 00000001 84272b00
Aug 17 07:34:20 raspberry kernel: 1d60: 00000001 832b5d00 00fb2fbd 0000001f 00000000 00000000 83120d98 8311be68
Aug 17 07:34:20 raspberry kernel: 1d80: 00000000 cb04b4e6 80261d88 83120800 84272b18 00000000 84272b00 00000000
Aug 17 07:34:20 raspberry kernel: 1da0: 5ac3c35a 81205008 88f31dec 88f31db8 7f41093c 7f4105d0 82632668 83120980
Aug 17 07:34:20 raspberry kernel: 1dc0: 88f31df4 7f3d7024 83120800 84272b00 00000000 84272bb4 00000000 5ac3c35a
Aug 17 07:34:21 raspberry kernel: 1de0: 88f31e04 88f31df0 7f410ab0 7f4108dc 84272b00 7f4be020 88f31e2c 88f31e08
Aug 17 07:34:21 raspberry kernel: 1e00: 7f4b3330 7f410a88 84272b00 00000000 84272bb4 84272bb4 8312089c 5ac3c35a
Aug 17 07:34:21 raspberry kernel: 1e20: 88f31e4c 88f31e30 7f4b3420 7f4b3274 84272b00 7f4be020 00000000 84272bb4
Aug 17 07:34:21 raspberry kernel: 1e40: 88f31e6c 88f31e50 7f4b4864 7f4b337c 84272b00 83120800 831208b0 7f432080
Aug 17 07:34:21 raspberry kernel: 1e60: 88f31e9c 88f31e70 7f410268 7f4b47e0 81205008 83120800 83120800 85002300
Aug 17 07:34:22 raspberry kernel: 1e80: 83120878 837b3440 819ab490 5ac3c35a 88f31ebc 88f31ea0 7f3d86e4 7f4101f0
Aug 17 07:34:22 raspberry kernel: 1ea0: 8360c540 000a201f 8414f258 83974bb0 88f31ef4 88f31ec0 803a2dd8 7f3d8558
Aug 17 07:34:22 raspberry kernel: 1ec0: 88f31ef4 88f31ed0 80261d88 8026367c 8360c540 00000000 832b627c 832b5d00
Aug 17 07:34:22 raspberry kernel: 1ee0: 81349d20 5ac3c35a 88f31f04 88f31ef8 803a2fb8 803a2d50 88f31f2c 88f31f08
Aug 17 07:34:22 raspberry kernel: 1f00: 8014f5f4 803a2fac ffffe000 88f31fb0 80100204 00000004 fffffe30 5ac3c35a
Aug 17 07:34:22 raspberry kernel: 1f20: 88f31fac 88f31f30 8010f2e4 8014f560 803a30f8 8014f34c 00000000 8120500c
Aug 17 07:34:23 raspberry kernel: 1f40: 88f31f6c 88f31f50 80399ae4 803a3078 00000000 830c1100 830c1140 8360c540
Aug 17 07:34:23 raspberry kernel: 1f60: 88f31f94 88f31f70 803ca608 80399a84 00000000 0221b268 03216520 cb04b4e6
Aug 17 07:34:23 raspberry kernel: 1f80: 80100204 00000000 0221b268 03216520 00000006 80100204 88f30000 00000006
Aug 17 07:34:23 raspberry kernel: 1fa0: 00000000 88f31fb0 80100074 8010ed00 00000000 00000002 00000000 00000000
Aug 17 07:34:23 raspberry kernel: 1fc0: 00000000 0221b268 03216520 00000006 0342d73c 00000000 0221b268 00000000
Aug 17 07:34:23 raspberry kernel: 1fe0: 00000006 7ec5fab0 76f15461 76f17526 880b0030 00000000 00000000 00000000
Aug 17 07:34:23 raspberry kernel: Backtrace:
Aug 17 07:34:23 raspberry kernel: [<7f4f01d8>] (vc4_hdmi_encoder_pre_crtc_configure [vc4]) from [<7f4d992c>] (vc4_crtc_atomic_enable+0x74/0x560 [vc4])
Aug 17 07:34:24 raspberry kernel: r9:00000000 r8:7f5010b0 r7:83121284 r6:84431040 r5:87833c00 r4:84431040
Aug 17 07:34:24 raspberry kernel: [<7f4d98b8>] (vc4_crtc_atomic_enable [vc4]) from [<7f4a8e40>] (drm_atomic_helper_commit_modeset_enables+0x228/0x278 [drm_kms_helper
Aug 17 07:34:24 raspberry kernel: r10:83120800 r9:00000000 r8:7f5010b0 r7:7f4bc028 r6:84431040 r5:87833c00
Aug 17 07:34:24 raspberry kernel: r4:00000003
Aug 17 07:34:24 raspberry kernel: [<7f4a8c18>] (drm_atomic_helper_commit_modeset_enables [drm_kms_helper]) from [<7f4e24f4>] (vc4_atomic_complete_commit+0x1b8/0x680
Aug 17 07:34:24 raspberry kernel: r10:83120800 r9:00000000 r8:83120ce8 r7:83c97840 r6:83120800 r5:87833c00
Aug 17 07:34:24 raspberry kernel: r4:00000000 r3:00000004
Aug 17 07:34:25 raspberry kernel: [<7f4e233c>] (vc4_atomic_complete_commit [vc4]) from [<7f4e2b40>] (vc4_atomic_commit+0x184/0x1d4 [vc4])
Aug 17 07:34:25 raspberry kernel: r10:83120800 r9:00000000 r8:83120ce8 r7:00000000 r6:00000000 r5:83120800
Aug 17 07:34:26 raspberry kernel: r4:87833c00 r3:00000001
Aug 17 07:34:27 raspberry kernel: [<7f4e29bc>] (vc4_atomic_commit [vc4]) from [<7f3f6150>] (drm_atomic_commit+0x54/0x60 [drm])
Aug 17 07:34:28 raspberry kernel: r9:82597af0 r8:830bd240 r7:88f31d60 r6:83120800 r5:87833c00 r4:00000000
Aug 17 07:34:28 raspberry kernel: [<7f3f60fc>] (drm_atomic_commit [drm]) from [<7f410824>] (drm_client_modeset_commit_atomic+0x260/0x290 [drm])
Aug 17 07:34:28 raspberry kernel: r7:88f31d60 r6:00000001 r5:831209c0 r4:87833c00
Aug 17 07:34:28 raspberry kernel: [<7f4105c4>] (drm_client_modeset_commit_atomic [drm]) from [<7f41093c>] (drm_client_modeset_commit_locked+0x6c/0x1ac [drm])
Aug 17 07:34:28 raspberry kernel: r10:81205008 r9:5ac3c35a r8:00000000 r7:84272b00 r6:00000000 r5:84272b18
Aug 17 07:34:28 raspberry kernel: r4:83120800
Aug 17 07:34:28 raspberry kernel: [<7f4108d0>] (drm_client_modeset_commit_locked [drm]) from [<7f410ab0>] (drm_client_modeset_commit+0x34/0x50 [drm])
Aug 17 07:34:29 raspberry kernel: r9:5ac3c35a r8:00000000 r7:84272bb4 r6:00000000 r5:84272b00 r4:83120800
Aug 17 07:34:29 raspberry kernel: [<7f410a7c>] (drm_client_modeset_commit [drm]) from [<7f4b3330>] (drm_fb_helper_set_par+0xc8/0x108 [drm_kms_helper])
Aug 17 07:34:29 raspberry kernel: r5:7f4be020 r4:84272b00
Aug 17 07:34:31 raspberry kernel: [<7f4b3268>] (drm_fb_helper_set_par [drm_kms_helper]) from [<7f4b3420>] (drm_fb_helper_hotplug_event.part.5+0xb0/0xc8 [drm_kms_help
Aug 17 07:34:31 raspberry kernel: r9:5ac3c35a r8:8312089c r7:84272bb4 r6:84272bb4 r5:00000000 r4:84272b00
Aug 17 07:34:31 raspberry kernel: [<7f4b3370>] (drm_fb_helper_hotplug_event.part.5 [drm_kms_helper]) from [<7f4b4864>] (drm_fbdev_client_restore+0x90/0xa8 [drm_kms_h
Aug 17 07:34:32 raspberry kernel: r7:84272bb4 r6:00000000 r5:7f4be020 r4:84272b00
Aug 17 07:34:32 raspberry kernel: [<7f4b47d4>] (drm_fbdev_client_restore [drm_kms_helper]) from [<7f410268>] (drm_client_dev_restore+0x84/0xc8 [drm])
Aug 17 07:34:33 raspberry kernel: r7:7f432080 r6:831208b0 r5:83120800 r4:84272b00
Aug 17 07:34:34 raspberry kernel: [<7f4101e4>] (drm_client_dev_restore [drm]) from [<7f3d86e4>] (drm_release+0x198/0x19c [drm])
Aug 17 07:34:36 raspberry kernel: r9:5ac3c35a r8:819ab490 r7:837b3440 r6:83120878 r5:85002300 r4:83120800
Aug 17 07:34:36 raspberry kernel: [<7f3d854c>] (drm_release [drm]) from [<803a2dd8>] (__fput+0x94/0x25c)
Aug 17 07:34:36 raspberry kernel: r7:83974bb0 r6:8414f258 r5:000a201f r4:8360c540
Aug 17 07:34:36 raspberry kernel: [<803a2d44>] (__fput) from [<803a2fb8>] (____fput+0x18/0x1c)
Aug 17 07:34:36 raspberry kernel: r9:5ac3c35a r8:81349d20 r7:832b5d00 r6:832b627c r5:00000000 r4:8360c540
Aug 17 07:34:37 raspberry kernel: [<803a2fa0>] (____fput) from [<8014f5f4>] (task_work_run+0xa0/0xcc)
Aug 17 07:34:39 raspberry kernel: [<8014f554>] (task_work_run) from [<8010f2e4>] (do_work_pending+0x5f0/0x5f8)
Aug 17 07:34:40 raspberry kernel: r9:5ac3c35a r8:fffffe30 r7:00000004 r6:80100204 r5:88f31fb0 r4:ffffe000
Aug 17 07:34:40 raspberry kernel: [<8010ecf4>] (do_work_pending) from [<80100074>] (slow_work_pending+0xc/0x20)
Aug 17 07:34:40 raspberry kernel: Exception stack(0x88f31fb0 to 0x88f31ff8)
Aug 17 07:34:40 raspberry kernel: 1fa0: 00000000 00000002 00000000 00000000
Aug 17 07:34:41 raspberry kernel: 1fc0: 00000000 0221b268 03216520 00000006 0342d73c 00000000 0221b268 00000000
Aug 17 07:34:41 raspberry kernel: 1fe0: 00000006 7ec5fab0 76f15461 76f17526 880b0030 00000000
Aug 17 07:34:41 raspberry kernel: r10:00000006 r9:88f30000 r8:80100204 r7:00000006 r6:03216520 r5:0221b268
Aug 17 07:34:41 raspberry kernel: r4:00000000
Aug 17 07:34:41 raspberry kernel: Code: e5953034 e3a01004 e5150008 e2800010 (e5937280)
Aug 17 07:34:41 raspberry kernel: ---[ end trace f14f48ea07f1dc69 ]---
Aug 17 07:37:26 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:26 raspberry mediacenter[622]: Cannot connect to server socket err = No such file or directory
Aug 17 07:37:26 raspberry mediacenter[622]: Cannot connect to server request channel
Aug 17 07:37:26 raspberry mediacenter[622]: jack server is not running or cannot be started
Aug 17 07:37:26 raspberry mediacenter[622]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 07:37:27 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:27 raspberry mediacenter[622]: Cannot connect to server socket err = No such file or directory
Aug 17 07:37:27 raspberry mediacenter[622]: Cannot connect to server request channel
Aug 17 07:37:27 raspberry mediacenter[622]: jack server is not running or cannot be started
Aug 17 07:37:27 raspberry mediacenter[622]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 07:37:29 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:29 raspberry mediacenter[622]: Cannot connect to server socket err = No such file or directory
Aug 17 07:37:29 raspberry mediacenter[622]: Cannot connect to server request channel
Aug 17 07:37:29 raspberry mediacenter[622]: jack server is not running or cannot be started
Aug 17 07:37:29 raspberry mediacenter[622]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 07:37:31 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:31 raspberry mediacenter[622]: Cannot connect to server socket err = No such file or directory
Aug 17 07:37:31 raspberry mediacenter[622]: Cannot connect to server request channel
Aug 17 07:37:31 raspberry mediacenter[622]: jack server is not running or cannot be started
Aug 17 07:37:31 raspberry mediacenter[622]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 07:37:32 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:32 raspberry mediacenter[622]: Cannot connect to server socket err = No such file or directory
Aug 17 07:37:32 raspberry mediacenter[622]: Cannot connect to server request channel
Aug 17 07:37:32 raspberry mediacenter[622]: jack server is not running or cannot be started
Aug 17 07:37:32 raspberry mediacenter[622]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Aug 17 07:37:33 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:34 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:35 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:36 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:37 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:38 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:39 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:40 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:41 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:42 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:43 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:44 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:45 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:46 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:47 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:48 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:49 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:50 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:51 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:52 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:53 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:54 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:55 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:56 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:57 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:58 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:37:59 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:38:00 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:38:18 raspberry kernel: detected fb_set_par error, error code: -16
Aug 17 07:38:18 raspberry mediacenter[15672]: ioctl FBIOPUT_VSCREENINFO: Device or resource busy
Aug 17 07:38:33 raspberry kernel: vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Aug 17 07:38:33 raspberry mediacenter[15684]: Cannot connect to server socket err = No such file or directory
Aug 17 07:38:33 raspberry mediacenter[15684]: Cannot connect to server request channel
Aug 17 07:38:33 raspberry mediacenter[15684]: jack server is not running or cannot be started
Aug 17 07:38:33 raspberry mediacenter[15684]: JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Kodi Log
2021-08-17 07:38:38.201 T:15712 INFO <general>: No Devices found - retry: 1
2021-08-17 07:38:41.136 T:15713 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-08-17 07:38:41.137 T:15713 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=vc4hdmi,DEV=0"
2021-08-17 07:38:41.150 T:15713 INFO <general>: CAESinkALSA - Unable to open device "hdmi:CARD=vc4hdmi,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00" for pla
2021-08-17 07:38:41.154 T:15713 INFO <general>: CAESinkALSA - Unable to open device "hdmi:CARD=vc4hdmi,DEV=0" for playback
2021-08-17 07:38:41.154 T:15713 ERROR <general>: CAESinkALSA::Initialize - failed to initialize device "hdmi:CARD=vc4hdmi,DEV=0"
2021-08-17 07:38:41.155 T:15713 ERROR <general>: CActiveAESink::OpenSink - no sink was returned
2021-08-17 07:38:41.156 T:15712 ERROR <general>: ActiveAE::InitSink - returned error
