So for 5 minutes ago it worked, then I changed a few things and now it doesn’t work any longer. The things I changed was inside the Lircd.conf - so there should be no harm done.
Unfortunately the “KEY_OK” is the only one not working anymore. I’ve tried multiple times to reconfigure with irrecord. Nothing helps.
What should I do to make my “KEY_OK” work again?
