On the screen that you sent me it’s clear that you wrote “install console data”. It’s wrong, read Graham’s post again.
H
Oh god
Newbie life
Sorry
I correct and try again…
Sorry
So… I confirm that works if we don’t forget “-”…
Sorry for disturbance…
Thank you a lot ooZee and Tom
Best regards
Entering the loadkey command using the command-line works fine, but adding it to the /etc/rc.local does not work.
Here what I put in there:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
loadkeys de-latin1
exit 0
osmc@Vero4k:~$
Can you provide the output from running systemctl status rc-local ?
Checked rc.local has exec permissions?
That was it!
Did a “chmod +x” and if worked
. I guess then it was not correctly setup from the start, or overwriting with the editor reset the execute rights …
Thanks a lot for the hint!
