Still just discovering all the features and reading a lot in the forum.
I am wondering about my QWERTZ bluetooth keyboard (Rii mini i8+) which is not working correctly with language set to German and region to my country Austria. It still is acting like a US keyboard.
I have found out there is a way using console commands and then it should maybe work. Have to give it a try. Unfortunately I’m not even knowing how to enter console LOL. And there are so many different commands people were suggesting in different threads, none of which was ever marked as SOLUTION…
Is it planned or possible to let OSMC’s set Region/Language actually change the hardware keyboard layout to the matching region? Would be incredibly convenient …
To load the QWERTZ layout when vero starts you have to put a command into a file called rc.local. Start by typing
sudo nano /etc/rc.local
You will now be editing the file. You should see this on your screen:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
Use the cursor keys to go to the line just above where it says exit 0 and enter this line:
I have same love for my VERO 4K and same problem with my french AZERTY Rii mini i8+.
I precise that my VERO 4K is setting with language set to French and region Switzerland.
Same problem - same solution!!
Look again at the earlier posts, and follow the remedial action listed there.
If that doesn’t work, then we’ll need as mush detail as you can provide on what you did, and what happened as a result.
Derek
So you confirm that is the same code :“loadkeys de-latin1” for my french AZERTY keyboard ?
Because in Deutchland they have QWERTZ keyboard and not AZERTY
I try to follow your process but nothing works.
I can read at the end : cannot open file fr-latin9, or file fr1-latin1 or file fr, regarding I tryed to write…
