Hi guys,
I have the latest build on my RPi 2 and by using the default web interface I saw that most keyboard shortcuts are not working. only the arrows Enter and Backspace are working properly.
Is there a way to fix that?
Thank you,
Miltos
Hi guys,
Thank you,
Miltos
it it the “remote” on the default kodi website that does not work?
or the real keyboard shortcuts for your physical keyboard peripherals.
Hi @HarryL,
The website “osmc.local” under Remote.
Does the issue also occur on other platforms (windows, linux) since Isengard?
I did not test it. I run OSMC on a RPi 2
