I would like to be able to to able to separate kids movies from other movies, however if you add a directory called ‘kids movies’ to the library kid’s movies gets bundled with ‘adult’ movies. (horrible term).
Perhaps the feature i’m asking for a second (and separate) library to provide for the separation.
I create a favorites shortcut to each genre directory, then customize the skin menu to show each favorite as a submenu under movies.
Children, comedy, drama, horror, scifi, etc
thanks, how did you create submenu of favorite under movies? I created smart playlist based on path, added to favorite and it works, however when i can only add ‘addons’ to the video submenu.
I’m using confluence skin? What skin do you use? Do i need an addon to turn favorites onto menu items?
