Kodi Krypton development is well underway, and the final release is expected shortly. We've been working hard preparing OSMC and rebasing our improvements on top of Kodi Krypton.
Very nice work OSMC team! I just installed the test build. From my understanding the new OSMC skin is not out yet but is on the way? I was greeted with the familiar default Estuary skin of Krypton like on my Linux pc though. I take it installing Osmc Krypton fresh when it is in it’s stable form will still have the usual set up prompts and let you choose the Estuary or Osmc skin?
Gotcha, I understand it’s still in development Sam. I was also just now wondering if the “My Osmc” menu will have those side tiles like the previous version. Well I look forward to testing out the new Osmc skin when it’s made available to me.
I haven’t tested it since I don’t have n ftp server configured, but in the new Kodi Krypton default Estuary skin, it seems you can still configure ftp by going to:
IMHO, once I change some setting, it should be stored on settings file. If not on just that moment, once I exit settings dialog. Is not much to ask for.
In not sure you understand this part. This behavior is simply how Kodi is designed to run. OSMC cannot change this. While Kodi runs, the guisettings.xml file is open. While changes to Kodi settings are made within the GUI, these changes are made to the open file. But the file is not closed and permanently written these changes until Kodi is gracefully shutdown.
If Kodi is having a problem with graceful shutdowns and only saves changes when using the exit function, then this indicates a problem with your installation. We’ll need to see a complete set of debug enabled logs that demonstrate the issue in order to continue here. You should do so in a new and appropriately titled thread so we don’t continue in this release announcement thread.
