Hello,
After upgrading to Kodi 18.2 RC1 I’m unable to install addons or zip repositories. Always the install fail! The unknown sources is enable.
Anyone knows how to fix the issue?
Thanks in advance
Hello,
Thanks in advance
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Try updating the repository first
Hello,
Sorry for the delay.
Please find the log report link below.
https://paste.osmc.tv/macoxiposo
Many thanks
Hello,
Many thanks
52.083405] Voltage normalised (0x00000000)
[ 821.793715] logitech-hidpp-device 0003:046D:4024.0004: HID++ 2.0 device connected.
[ 867.448283] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 867.448301] Under-voltage detected! (0x00050005)
[ 871.608366] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 871.608384] Voltage normalised (0x00000000)
[ 942.329137] Under-voltage detected! (0x00050005)
[ 946.489117] Voltage normalised (0x00000000)
[ 1000.569989] Under-voltage detected! (0x00050005)
[ 1006.809390] Voltage normalised (0x00000000)
[ 1248.091850] rpi_firmware_get_throttled: 1 callbacks suppressed
[ 1248.091869] Under-voltage detected! (0x00050005)
[ 1252.251809] rpi_firmware_get_throttled: 1 callbacks suppressed
[ 1252.251821] Voltage normalised (0x00000000)
[ 1275.131969] Under-voltage detected! (0x00050005)
[ 1281.372103] Voltage normalised (0x00000000)
[ 1325.053030] Under-voltage detected! (0x00050005)
[ 1331.292594] Voltage normalised (0x00000000)
[ 1549.695027] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 1549.695043] Under-voltage detected! (0x00050005)
[ 1558.014779] rpi_firmware_get_throttled: 2 callbacks suppressed
[ 1558.014792] Voltage normalised (0x00000000)
[ 1751.456581] Under-voltage detected! (0x00050005)
[ 1757.696579] Voltage normalised (0x00000000)
[ 1855.457554] Under-voltage detected! (0x00050005)
[ 1859.617630] Voltage normalised (0x00000000)
[ 1872.097901] Under-voltage detected! (0x00050005)
[ 1876.257575] Voltage normalised (0x00000000)
[ 2159.140046] Under-voltage detected! (0x00050005)
[ 2167.460081] Voltage normalised (0x00000000)
[ 2171.620224] Under-voltage detected! (0x00050005)
[ 2177.860236] Voltage normalised (0x00000000)
[ 2444.102700] Under-voltage detected! (0x00050005)
[ 2448.262420] Voltage normalised (0x00000000)
[ 2464.902795] Under-voltage detected! (0x00050005)
[ 2471.142660] Voltage normalised (0x00000000)
[ 2562.663418] Under-voltage detected! (0x00050005)
[ 2568.903484] Voltage normalised (0x00000000)
[ 2645.863968] Under-voltage detected! (0x00050005)
[ 2652.104350] Voltage normalised (0x00000000)
[ 2768.584795] rpi_firmware_get_throttled: 1 callbacks suppressed
[ 2768.584812] Under-voltage detected! (0x00050005)
[ 2776.904731] rpi_firmware_get_throttled: 1 callbacks suppressed
[ 2776.904742] Voltage normalised (0x00000000)
[ 2982.826112] Under-voltage detected! (0x00050005)
[ 2989.066352] Voltage normalised (0x00000000)
[ 3072.267389] Under-voltage detected! (0x00050005)
[ 3078.506902] Voltage normalised (0x00000000)
[ 3378.029090] Under-voltage detected! (0x00050005)
[ 3384.268937] Voltage normalised (0x00000000)
[ 3477.869580] Under-voltage detected! (0x00050005)
[ 3484.109648] Voltage normalised (0x00000000)
[ 3552.750063] Under-voltage detected! (0x00050005)
[ 3556.909907] Voltage normalised (0x00000000)
[ 3681.710994] Under-voltage detected! (0x00050005)
[ 3690.030718] Voltage normalised (0x00000000)
[ 3692.111156] Under-voltage detected! (0x00050005)
[ 3696.270752] Voltage normalised (0x00000000)
[ 3698.350943] Under-voltage detected! (0x00050005)
[ 3704.590659] Voltage normalised (0x00000000)
Your pi is starved for power. You need to sort out your power problems and use an appropriate PSU.
Thank you,
I already got it but before the upgrade to the Koi 18.2 RC1 I’m able to install and manage the addons! Not now
Until you get a proper power supply, you will have problems. Your supply was probably marginal before and V18 does use more CPU, so your marginal power supply (my bet is really a cell phone charger) is no longer capable of supplying enough power.
Your power supply probably isn’t up to scratch. You can learn more on our Wiki here: Frequently Asked Questions - Raspberry Pi - OSMC
2 posts were merged into an existing topic: 18 RC2 update stops wireless keyboard from responding normally
Hello Sam,
I know that the power is not enough but why I can´t update my addons?
Please check the log file at: https://paste.osmc.tv/aqucakoves
Thanks in advance.
Possibly related to this message in the log:
2019-06-16 11:32:43.620 T:2979697872 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/kodi/addons: No such file or directory'
Losing the whole directory and its contents might be the result of a corrupted SD card. To get the addons back you need to reinstall the rbp1-mediacenter-osmc package.
sudo apt-get install --reinstall rbp1-mediacenter-osmc
but be aware that this might not be the only error on the card.
I would also suggest that you remove the stretch-devel line from /etc/apt/sources.list unless you are sure it needs to be there.
Thank you for your reply.
The presented solution doesn’t solve the problem!
Please send me other possible solutions.
It seems like your SD card may be problematic.
Some SD cards are not genuine or have a lower capacity than advertised. Some simply fail over time.
Symptoms of SD cards not working correctly are:
Symptoms of counterfeit SD cards are:
Counterfeit cards are usually found on Amazon and eBay.
SD cards have a limited lifespan. I recommend you change SD card and suspect that issues will no longer persist with a good card. If you would like to be a good quality SD card purpose manufactured for OSMC, then you can find one in the Store.
The SD card is fine, its’ a 8GB Samsung and I perform to the dist-upgrade without problems.
The problem is the addons update/install and the movies database update.
I’m unable to update from within this new Kodi release! How to rollback the Kodi?
Until you get a proper power supply, it’s useless to try and fix any other problems.
