im new to git, so…
so in the build.sh file i replace:
pull_source "https://github.com/xbmc/xbmc/archive/89472b7d690922366bbff5ba47d077f82a9f0ec1.tar.gz" "$(pwd)/src"
with:
pull_source "https://github.com/xbmc/xbmc/archive/18.4-Leia.tar.gz" "$(pwd)/src"
so make XYZ is:
make mediacenter-osmc.deb
Yes.
No – use a Makefile target (run make for examples)
-bash: make: command not found
You need to install the build packages (build-essential)
got it:
make vero3
compiling now
got this at the end of the build:
Applying patch all-064-Use-OSMC-mirror-system-for-Kodi-addon-repository.patch
patching file addons/repository.xbmc.org/addon.xml
Hunk #1 FAILED at 1.
1 out of 1 hunk FAILED – saving rejects to file addons/repository.xbmc.org/addon.xml.rej
Exiting build with return code 1
Makefile:14: recipe for target ‘vero3’ failed
make: *** [vero3] Error 1
make: Leaving directory ‘/mnt/package/mediacenter-osmc’
make: *** [vero3] Error 2
You need to rebase the patches
Alternatively you can wait for an official build
rebase the patches how?
when is an official build for 18.4 coming?
You would need to fix them against the Git tree.
We will test v18.4 before releasing it and get some other fixes in. It will take a few days.
yea, that went right over my head, LOL
OH, so 18.4 is coming soon, why didnt you say that in the first place?
We always release minor Kodi versions a few days afterwards.
See Keeping your OSMC system up to date - General - OSMC
Any news on an 18.4 OSMC update? There are some bug fixes that were backported into this release that I’m quite eager to have.
Soon – just a few more days. There are some major issues with some of the binary add-ons.
any updates?
18.4 is in staging.
installed and testing, i can confirm the Aspect Ratio Display bug is fixed!
Glad to hear this.
i have seen a few updates since i installed the staging release…
