Kodi 18 Leia + Skin MIMIC -- SOLVED ---
Hello, I have a clean installation and I just installed the Mimic skin, everything is perfect except I do not know how to do it or if possible, add or remove elements from the main menu. There is no option to add or remove items.
Thank you
Probably best to ask the Mimic skin developer as they will know.
Thank you, he discovered that pressing the letter C activates a new menu with the options.
