Since the topic “V18 - Suspend not working” is marked as solved, I open a new topic.
With Kodi 18 my Vero 4K+ wasn´t able to suspend anymore so I followed post #32 (see “V18 - Suspend not working”) and updated my Vero.
Now after the update I´m finally able to suspend the device and the red LED turns on but after couple of minutes the LED turns off. If I turn the TV on I immediately see the Kodi home screen.
I´m using the default OSMC skin without any special addons.
I have only the standard remote and during my tests didn´t run the iOS Kodi Remote.
HDMI CEC isn´t active.
I created the log files:
after the restart I suspended the Vero. After powerup I created the logs (I deleted lines with information about my movies/series)
I know, I used the stretch-devel main repo as you suggested in the other topic.
And it solved the problem partially, because before the update suspend was 80% unsuccessful: after hitting suspend the Vero came back immediately.
With the devel update suspend works always, but after 5-10 Minutes Vero comes back.
the May-Update didn´t solve the problem so I reinstalled the Vero and configured only basic things (OSMC home screen, fstab). Right now everything is perfect, suspend works.
I think the Skin Helper´s “In progress movies” widget caused previously the problem.
Do you know a different way to create an “in progress” movie widget which doesn´t wake up the device?
