[Deprecated] Kodi 19 (Matrix) nightly builds for Vero 2 & 4K
NOTE: 3 Dec 2020 The public key for the repo has been updated. You will need to import the latest key:
wget -qO - http://download.osmc.tv/dev/gmc-19/public/pubkey-2020.asc | sudo apt-key add -**
With Kodi Leia now branched, the master is on Matrix (v19)
Previous Leia nightlies can be found here.
OSMC Test Builds for Kodi (Matrix) 19 for Vero2 and 4k(+)
Warning
Kodi 19 is currently in Alpha and there is likely to be a lot of activity in the coming months. As these are alpha builds expect some issues.
Kodi has now merged the changes for Python3. If addon devā€™s have not updated their builds for Python 3 then expect breakages.
If you are looking for a stable system then these builds are not for you!
Before proceeding make sure you have a backup of your Vero As these are test builds there could well be some unexpected problems.
Database upgrades could also be an issue. Please make a backup of the Kodi database before installing, especially if you are running a remote MySQL database. Going back from v18 to stable might be difficult especially if there have been upgrades to the Kodi databases.
Installing
You need a working system in order to install these test builds. If you do not have OSMC already installed then go to https://osmc.tv/download/ to install the latest stable version.
Update apt source list to get the latest nightly:
Edit
sudo nano /etc/apt/sources.list
deb http://download.osmc.tv/dev/gmc-19/public gmc-19 main
Save and exit file.
Import gpg certificate:
Finally run update and dist-upgrade to install latest nightly.
sudo apt-get update
sudo apt-get dist-upgrade
Going back to Stable branch (No guarantees that it will work)
Edit sources.list file and change line to:
#deb http://download.osmc.tv/dev/gmc-19/public gmc-19 main
Updating
When new updates are released you can either update using MyOSMC or manually with the following commands:
sudo apt-get update
To confirm which version you are running:
dpkg -l | grep mediacenter-osmc | awk '{ print $3 }'
Check which versions are available should you wish to install a previous version:
apt-cache madison rbp2-mediacenter-osmc
Install previous versions:
sudo apt-get install vero3-mediacenter-osmc=version
sudo apt-get install vero2-mediacenter-osmc=version
Where version=version number (eg 18.8-34)
Support
Since we are in alpha there could be a lot of incompatibilities with skins and addons. To resolve these its best taking the issue up with the addon developer.
If you have any issues with OSMC please provide debug logs. Most problems are almost impossible to fix if we donā€™t have the debug logs.
How to submit a useful support request
Archive:
http://kodi.gjmccarthy.co.uk
Current Build
Previous Builds
18.8-25, 22 April 2019: Based off OSMC commit (7406420dfb4) and newclock5 (f557accb02)
OSMC
  • Bump branch to gmc-19
  • Resync all patches with OMSC master (OSMC v18 now released)
XBMC:
  • Bump to v19 alpha1 (PR:15920, 2 commits, 2 files changed)
  • [cmake] enable using ccache with xcode (PR:15886, 1 commit, 1 file changed)
  • [Docs] Add xrefitems for v19 (python and skinning engine) (PR:15133, 1 commit, 3 files changed)
  • [PVR] Feature: PVR Reminders (PR:15467, 8 commits, 100 files changed)
  • [guilib][guiinfo][video][Estuary] Feature: Seek dialog: Add EDL and chapter marker visualisation. (PR:15767, 2 commits, 19 files changed)
  • [PVR] Inconsistencies in Guide/Channel/Recordings Info Dialogs (PR:15648, 1 commit, 4 files changed)
  • Add addon settingslevel button (PR:15796, 2 commits, 4 files changed)
  • [Kodi] Removed unused string (PR:14528, 1 commit, 1 file changed)
  • [json-rpc][pvr] Recordings: add fields season, episode and showtitle (PR:15869, 1 commit, 2 files changed)
  • Improve default keyboardlayout (PR:15687, 1 commit, 1 file changed)
  • [guiinfo] Fix crash in CPlayerGUIInfo::GetContentRanges. (PR:15930, 1 commit, 1 file changed)
  • Remove dead code for static libdvdnav (PR:15925, 1 commit, 1 file changed)
  • CEGLImage: dump attributes if the import fails (PR:15885, 2 commits, 2 files changed)
  • [cleanup] remove unused AMLUtils functions (PR:15933, 1 commit, 2 files changed)
  • [VideoInfoScanner] donā€™t call CVideoInfoDownloader::GetArtwork if plugin is used as a video source (PR:15921, 1 commit, 1 file changed)
  • [GBM] CRendererDRMPRIMEGLES improvements (PR:15928, 4 commits, 5 files changed)
  • CDRMUtils: rework modifiers flag selection (PR:15922, 1 commit, 1 file changed)
inputstream.adaptive:
  • Version bump 2.3.17 (1a7dafd)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (1a7dafde) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , game.libretro.mupen64plus (5b620f27) , game.libretro.pcsx-rearmed (26804844) , pvr.waipu (73a1e42d, +1), pvr.sledovanitv.cz (2e3a7e24) , pvr.argustv (83aa1e9c) , pvr.mythtv (179b6ea5) , pvr.hts (8dcd62db) , pvr.pctv (b60b9710) , pvr.stalker (d0170c5b) , pvr.filmon (e8506330) , pvr.octonet (203f800e) , pvr.zattoo (7d004abc) , pvr.vbox (ea20464e) , pvr.wmc (7b28be39) , pvr.nextpvr (c104d956) , pvr.njoy (4467cacf) , pvr.teleboy (1956113e) , pvr.vdr.vnsi (cbb75abb) , pvr.vuplus (4f0de0e3) , pvr.dvbviewer (c2c1beb8) , pvr.dvblink (ecc9cfdd) , pvr.hdhomerun (a9d73097) , pvr.iptvsimple (73feb2f4) , pvr.demo (964686dc) , pvr.mediaportal.tvserver (931afab5) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-28, 26 April 2019: Based off OSMC commit (28a4d0e3) and newclock5 (f557accb02)
OSMC
  • Vero 4: Fix resolutions on edid change
  • Vero 4K: fix banding issues
  • Fix resolution being set low when updating from Kodi Krypton
pvr.waipu
  • Fix build version shown in Kodi (73a1e42)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (1a7dafde) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , game.libretro.mupen64plus (5b620f27) , game.libretro.pcsx-rearmed (26804844) , pvr.waipu (905b1c59, +1), pvr.sledovanitv.cz (2e3a7e24) , pvr.argustv (83aa1e9c) , pvr.mythtv (179b6ea5) , pvr.hts (8dcd62db) , pvr.pctv (b60b9710) , pvr.stalker (d0170c5b) , pvr.filmon (e8506330) , pvr.octonet (203f800e) , pvr.zattoo (7d004abc) , pvr.vbox (ea20464e) , pvr.wmc (7b28be39) , pvr.nextpvr (c104d956) , pvr.njoy (4467cacf) , pvr.teleboy (1956113e) , pvr.vdr.vnsi (cbb75abb) , pvr.vuplus (4f0de0e3) , pvr.dvbviewer (c2c1beb8) , pvr.dvblink (ecc9cfdd) , pvr.hdhomerun (a9d73097) , pvr.iptvsimple (73feb2f4) , pvr.demo (964686dc) , pvr.mediaportal.tvserver (931afab5) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
Iā€™m still on 18.8-23, is it possible?
I found a error in the builds which is causing the latest version not to appear. Working on a fix.
Problem has been fixed so latest build should now install.
18.8-29, 27 April 2019: Based off OSMC commit (0900b70fa) and xbmc (ac7c75fb08)
XBMC:
  • [addons] add settings support for property condition (basic conditions only) (PR:15803, 1 commit, 1 file changed)
  • Matrix addon repository (PR:15986, 1 commit, 1 file changed)
  • VideoPlayerCodec: Ask Demuxer to seek for us (PR:15980, 1 commit, 1 file changed)
  • [PVR][addons][json-rpc][estuary][estouchy] PVR Addon API 6.0.0 (PR:15953, 10 commits, 31 files changed)
pvr.argustv:
  • Implement PVR addon API v6.0.0 (PR:87, 1 commit, 5 files changed)
  • build with Kodi Leia API (d459cba)
  • build with Kodi Matrix API (453d6de)
  • build with Kodi master API (c46ae87)
pvr.demo:
  • Implement PVR addon API v6.0.0 (PR:64, 1 commit, 4 files changed)
  • build with Kodi Leia API (9164983)
  • build with Kodi Matrix API (58fd195)
  • build with Kodi master API (3601518)
pvr.dvblink:
  • Implement PVR addon API v6.0.0 (PR:120, 1 commit, 5 files changed)
  • build with Kodi Leia API (71c6e42)
  • build with Kodi Matrix API (67814f0)
  • build with Kodi master API (462d093)
pvr.dvbviewer:
  • Implement PVR addon API v6.0.0 (PR:78, 1 commit, 5 files changed)
  • build with Kodi Leia API (d6254bd)
  • build with Kodi Matrix API (90a976c)
  • build with Kodi master API (a41163f)
pvr.filmon:
  • Implement PVR addon API v6.0.0 (PR:89, 1 commit, 6 files changed)
  • build with Kodi Leia API (26ce591)
  • build with Kodi Matrix API (865e616)
  • build with Kodi master API (c71f611)
pvr.hdhomerun:
  • Implement PVR addon API v6.0.0 (PR:82, 1 commit, 5 files changed)
  • build with Kodi Leia API (dbbf52e)
  • build with Kodi Matrix API (a700431)
  • build with Kodi master API (949db6c)
pvr.hts:
  • Fix playback when skipping an in progress recording to real-time (PR:413, 1 commit, 7 files changed)
  • 5.0.0: Implement PVR addon API v6.0.0 (PR:414, 1 commit, 7 files changed)
  • build with Kodi Leia API (b0a798b)
  • build with Kodi Matrix API (6d5ec31)
  • build with Kodi master API (8b06c17)
pvr.iptvsimple:
  • [depends] rapidxml: split windows from common (PR:240, 1 commit, 4 files changed)
  • Implement PVR addon API v6.0.0 (PR:239, 1 commit, 5 files changed)
  • build with Kodi Leia API (bd26207)
  • build with Kodi Matrix API (fb0f79e)
  • build with Kodi master API (fd357e4)
pvr.mediaportal.tvserver:
  • Implement PVR addon API v6.0.0 (PR:100, 1 commit, 5 files changed)
  • build with Kodi Leia API (3ba6535)
  • build with Kodi Matrix API (91192c2)
  • build with Kodi master API (34878ac)
pvr.mythtv:
  • build with Kodi Leia API (PR:118, 1 commit, 3 files changed)
  • Implement PVR addon API v6.0.0 (PR:119, 1 commit, 5 files changed)
  • build with Kodi Matrix API (3d7f313)
  • build with Kodi master API (728378f)
pvr.nextpvr:
  • Implement PVR addon API v6.0.0 (PR:94, 1 commit, 5 files changed)
  • build with Kodi Leia API (d02cc70)
  • build with Kodi Matrix API (9f05ba1)
  • build with Kodi master API (b971fff)
pvr.njoy:
  • Implement PVR addon API v6.0.0 (PR:49, 1 commit, 3 files changed)
  • build with Kodi Leia API (a31e20e)
  • build with Kodi Matrix API (075b95d)
  • build with Kodi master API (554c63c)
pvr.octonet:
  • build with Kodi Leia API (PR:25, 1 commit, 4 files changed)
  • Implement PVR addon API v6.0.0 (PR:26, 1 commit, 4 files changed)
  • build with Kodi Matrix API (9de3166)
  • build with Kodi master API (414e756)
pvr.pctv:
  • Implement PVR addon API v6.0.0 (PR:64, 1 commit, 5 files changed)
  • build with Kodi Leia API (09e6f7b)
  • build with Kodi Matrix API (4603184)
  • build with Kodi master API (1679bea)
pvr.stalker:
  • Implement PVR addon API v6.0.0 (PR:123, 1 commit, 5 files changed)
  • build with Kodi Leia API (05a4245)
pvr.teleboy:
  • build with Kodi Matrix API (73500d6)
  • build with Kodi master API (24b8048)
  • build with Kodi Leia API (PR:17, 1 commit, 1 file changed)
  • Implement PVR addon API v6.0.0 (PR:18, 1 commit, 5 files changed)
  • build with Kodi Matrix API (bfda6dc)
pvr.vbox:
  • Implement PVR addon API v6.0.0 (PR:218, 1 commit, 3 files changed)
  • build with Kodi Leia API (56d18dc)
  • build with Kodi Matrix API (7fae6b7)
  • build with Kodi master API (edaef25)
pvr.vdr.vnsi:
  • Fix skin.estuary folder name (PR:98, 1 commit, 2 files changed)
  • Fix libXBMC_codec.h include path (PR:97, 1 commit, 1 file changed)
  • generate 2 read-only child timers for manual repeating, allows wakeup (PR:99, 1 commit, 4 files changed)
  • fix episode name on recordings (PR:101, 1 commit, 1 file changed)
  • fix install path (PR:103, 1 commit, 1 file changed)
  • ensure lib is installed into multiarch path (PR:104, 1 commit, 1 file changed)
  • simplify installation file (PR:105, 1 commit, 1 file changed)
  • v3.6.3 - kodi-pvr is upstream repo again, ā€¦ (PR:116, 1 commit, 76 files changed)
  • Implement PVR addon API v6.0.0 (PR:117, 1 commit, 5 files changed)
  • [lang] updated language files from Transifex (64d7033)
  • [lang] updated language files from Transifex (30f12bb)
  • bump protocol to 10, fixes for search timers (4149574)
  • bump version to 2.6.12 (0659c65)
  • point travis to branch Krypton (90aa7f0)
  • bump version to 2.6.14 (ab2be92)
  • [lang] updated language files from Transifex (47f9dec)
  • [lang] updated language files from Transifex (0c9552e)
  • bump version to 2.6.17 (2a90c2f)
  • [lang] updated language files from Transifex (dcdc216)
  • [lang] updated language files from Transifex (ab5c158)
  • [lang] updated language files from Transifex (7a17f89)
  • [lang] updated language files from Transifex (4ed7d60)
  • [lang] updated language files from Transifex (4457597)
  • Update README.md (4f1ac54)
  • GetRecordingsList: fix variable names (078c52c)
  • bump version (fa1e4f5)
  • [lang] updated language files from Transifex (782590c)
  • [lang] updated language files from Transifex (e8f8289)
  • [lang] updated language files from Transifex (e5dc3dd)
  • [lang] updated language files from Transifex (1ebc4c9)
  • [lang] updated language files from Transifex (dbbe1d0)
  • [lang] updated language files from Transifex (f7811cb)
  • [lang] updated language files from Transifex (a3cd179)
  • [lang] updated language files from Transifex (8c93a00)
  • [lang] automatic syntax corrections for the en_GB language file (9244fed)
  • [lang] updated language files from Transifex (198862e)
  • [lang] updated language files from Transifex (de2c0c1)
  • [lang] updated language files from Transifex (730414b)
  • [lang] updated language files from Transifex (aa23601)
  • Merge remote-tracking branch ā€˜FernetMenta/pvr.vdr.vnsi/masterā€™ - making kodi-pvr upstream again. (976f722)
  • Change travis and readme to reflect kodi-pvr is upstream again. (e62f61c)
  • fix travis CI (373b609)
  • fix travis CI (7915152)
  • build with Kodi Leia API (4909f69)
  • build with Kodi Matrix API (d362807)
  • build with Kodi master API (8ef4de9)
[b]pvr.vuplus:
  • Implement PVR addon API v6.0.0 (PR:211, 1 commit, 6 files changed)
  • build with Kodi Leia API (f946635)
  • build with Kodi Matrix API (e66a9b7)
  • build with Kodi master API (7317fd7)[/b]
pvr.wmc:
  • Implement PVR addon API v6.0.0 (PR:68, 1 commit, 6 files changed)
  • build with Kodi Leia API (306f2d8)
  • build with Kodi Matrix API (0fac912)
  • build with Kodi master API (6a61f25)
pvr.zattoo:
  • build with Kodi Leia API (PR:45, 1 commit, 3 files changed)
  • Implement PVR addon API v6.0.0 (PR:46, 1 commit, 5 files changed)
  • build with Kodi Matrix API (38b170a)
  • build with Kodi master API (07a524a)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (1a7dafde) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , game.libretro.mupen64plus (5b620f27) , game.libretro.pcsx-rearmed (26804844) , pvr.waipu (1b1b7b67) , pvr.sledovanitv.cz (6fe56379) , pvr.argustv (0c87131e) , pvr.mythtv (01069b3c) , pvr.hts (37c73bba) , pvr.pctv (58be1f87) , pvr.stalker (1f507876) , pvr.filmon (6de87d81) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (6c17fc42) , pvr.wmc (e50c316a) , pvr.nextpvr (892c065d) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (67254316) , pvr.vuplus (6c8e1ddc) , pvr.dvbviewer (d5bde516) , pvr.dvblink (a47533a8) , pvr.hdhomerun (e5e6d9e9) , pvr.iptvsimple (b5f11666) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (a2bd151b) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
Not sure when this started being an issue and I am on the beta build but for some reason I can not longer jump forward or backward in a video. When you try and advance is advances 3 seconds only but when you try and go back it advances another 3 seconds. Large jumps forward and backwards (up and down) also do the same thing, just advance a little.
This seems to happen with any video be they local or streamed.
FTR I am using Vero4K with Version: 18.8-29 of vero3-mediacenter-osmc
Ideas?
Please always report issues with testing software in the testing thread. Also, itā€™s necessary and much more helpful and useful when making such bug reports to provide debug enabled logs demonstrating the issue.
I will investigate tomorrow. I will need a way to filter out the problem.
@lookidok always debug reports in the testing thread if your having an issue without those your issue will persist.
18.8-30, 29 April 2019: Based off OSMC commit (c294595a) and xbmc (ac7c75fb08)
OSMC:
  • Re-add pvr.waipu
XBMC:
  • PVR Addon API 6.0.0
pvr.vuplus:
  • Settings levels and timer fallback epg (matrix) (PR:213, 6 commits, 20 files changed)
pvr.waipu:
  • Adjust README (945173d)
  • Use StringToTime from pvr.zattoo instead of strptime; (62064bf)
  • fix: define timegm on windows (dfc120d)
  • Release version 1.0.0 (1b1b7b6)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (1a7dafde) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , game.libretro.mupen64plus (5b620f27) , game.libretro.pcsx-rearmed (26804844) , pvr.waipu (1b1b7b67, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (0c87131e) , pvr.mythtv (b0a72da6) , pvr.hts (37c73bba) , pvr.pctv (58be1f87) , pvr.stalker (1f507876) , pvr.filmon (6de87d81) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (6c17fc42) , pvr.wmc (e50c316a) , pvr.nextpvr (892c065d) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (67254316) , pvr.vuplus (8d8a4c55) , pvr.dvbviewer (d5bde516) , pvr.dvblink (a47533a8) , pvr.hdhomerun (e5e6d9e9) , pvr.iptvsimple (b5f11666) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (a2bd151b) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-31, 29 April 2019: Based off OSMC commit (c325319b3) and xbmc (657785ad3)
XBMC:
  • [addons] add dummy libraries to screensaver to prevent error (PR:16007, 1 commit, 2 files changed)
  • [addons] add GetTimeā€¦ function and possibility to get ID3D11DeviceContext all the time (PR:15609, 2 commits, 12 files changed)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (1a7dafde) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , game.libretro.mupen64plus (5b620f27) , game.libretro.pcsx-rearmed (26804844) , pvr.waipu (1b1b7b67, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (0c87131e) , pvr.mythtv (56176ab2) , pvr.hts (37c73bba) , pvr.pctv (58be1f87) , pvr.stalker (1f507876) , pvr.filmon (6de87d81) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (6c17fc42) , pvr.wmc (e50c316a) , pvr.nextpvr (892c065d) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (67254316) , pvr.vuplus (8d8a4c55) , pvr.dvbviewer (324db50d) , pvr.dvblink (a47533a8) , pvr.hdhomerun (e5e6d9e9) , pvr.iptvsimple (b5f11666) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (a2bd151b) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-32, 30 April 2019: Based off OSMC commit (c0149b542) and xbmc (f5578632b8a3)
XBMC:
  • [addons] Bring back audioengine addon interface (not ADSP) (PR:16006, 1 commit, 7 files changed)
  • [addons] add OpenGL support to the addon interface and allow GL usage via DirectX (PR:15610, 2 commits, 11 files changed)
  • [PVR] Rework epg db storage setting semantics. Default to ā€˜do not storeā€™ (PR:16005, 1 commit, 8 files changed)
  • CWinSystemGbm: only lock the front buffer if something is rendered (PR:15949, 1 commit, 1 file changed)
pvr.dvbviewer:
  • Add branch to readme (324db50)
pvr.mythtv:
  • fix includes for the elementary stream (56176ab)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (ca3632d8) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , pvr.waipu (1b1b7b67, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (0c87131e) , pvr.mythtv (56176ab2) , pvr.hts (37c73bba) , pvr.pctv (58be1f87) , pvr.stalker (1f507876) , pvr.filmon (6de87d81) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (6c17fc42) , pvr.wmc (e50c316a) , pvr.nextpvr (892c065d) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (67254316) , pvr.vuplus (8d8a4c55) , pvr.dvbviewer (324db50d) , pvr.dvblink (a47533a8) , pvr.hdhomerun (e5e6d9e9) , pvr.iptvsimple (b5f11666) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (a2bd151b) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-33, 1 May 2019: Based off OSMC commit (c0149b542) and xbmc (bc37d8dd)
XBMC:
  • [Estuary] favourites widget would not scroll to end on 16:10 displays (PR:16011, 1 commit, 1 file changed)
  • [cmake] make sure CXX11 is also always set for addons (PR:15987, 1 commit, 3 files changed)
  • DVDVideoCodecDRMPRIME: update process info in get format callback (PR:15964, 2 commits, 2 files changed)
  • Use fanart to hide spoilers if available (PR:15991, 1 commit, 1 file changed)
    *] [addons] use correct revision for kodi-platform (PR:16010, 1 commit, 1 file changed)
  • Fix formatting of VideoThumbLoader (PR:16019, 1 commit, 1 file changed)
  • fix return code of ParseFrameForSPS (PR:255, 1 commit, 1 file changed)
pvr.waipu:
  • [cmake] remove usage of kodi-platform (PR:3, 1 commit, 2 files changed)
  • release 1.0.1 (c6d131a)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (ca3632d8) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , pvr.waipu (c6d131ae, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (0c87131e) , pvr.mythtv (56176ab2) , pvr.hts (37c73bba) , pvr.pctv (58be1f87) , pvr.stalker (1f507876) , pvr.filmon (6de87d81) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (6c17fc42) , pvr.wmc (e50c316a) , pvr.nextpvr (892c065d) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (67254316) , pvr.vuplus (8d8a4c55) , pvr.dvbviewer (324db50d) , pvr.dvblink (a47533a8) , pvr.hdhomerun (e5e6d9e9) , pvr.iptvsimple (b5f11666) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (a2bd151b) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-34, 2 May 2019: Based off OSMC commit (b6fa521445) and xbmc (b0f931477e)
XBMC:
  • fixed: Resume bookmark would clear on player start failure (PR:16004, 1 commit, 1 file changed)
  • PAPlayer: Donā€™t fallback to DTS too early (PR:16026, 1 commit, 1 file changed)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (ca3632d8) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , pvr.waipu (c6d131ae, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (dec20f6e) , pvr.mythtv (56176ab2) , pvr.hts (9943d05c) , pvr.pctv (af868144) , pvr.stalker (f926a517) , pvr.filmon (5265b914) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (70732ccd) , pvr.wmc (38de15a2) , pvr.nextpvr (e72e4293) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (1defc992) , pvr.vuplus (8d8a4c55) , pvr.dvbviewer (324db50d) , pvr.dvblink (a960e89b) , pvr.hdhomerun (ebeb5dc8) , pvr.iptvsimple (b5f11666) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (045125be) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-35, 3 May 2019: Based off OSMC commit (913608c9a) and xbmc (d57182ca)
XBMC:
  • [PVR] Fix CPVREpg:SadAdd|Update)Entry to not overwrite channeldata and epgid (PR:16036, 1 commit, 1 file changed)
  • VideoBufferDRMPRIME: extract video buffer interface (PR:15963, 4 commits, 15 files changed)
  • [PVR] Newly added channels cause EPG UI corruption (PR:16033, 1 commit, 1 file changed)
pvr.argustv:
  • [cleanup] remove kodiplatform dependency (PR:90, 1 commit, 2 files changed)
pvr.dvblink:
  • [cmake] remove usage of kodi-platform (PR:121, 1 commit, 2 files changed)
pvr.filmon:
  • [cmake] remove usage of kodi-platform (PR:90, 1 commit, 2 files changed)
pvr.hdhomerun:
  • [cmake] remove usage of kodi-platform (PR:83, 1 commit, 2 files changed)
pvr.hts:
  • [cmake] remove usage of kodi-platform (9943d05)
pvr.iptvsimple:
  • [cmake] remove usage of kodi-platform (PR:242, 1 commit, 2 files changed)
  • [cmake] remove usage of kodi-platform (PR:101, 1 commit, 2 files changed)
pvr.nextpvr:
  • [cmake] remove usage of kodi-platform (PR:95, 1 commit, 2 files changed)
pvr.pctv:
  • [cmake] remove usage of kodi-platform (PR:65, 1 commit, 2 files changed)
pvr.stalker:
  • [cmake] remove usage of kodi-platform (PR:124, 1 commit, 2 files changed)
pvr.vbox:
  • [cmake] remove usage of kodi-platform (PR:219, 1 commit, 2 files changed)
pvr.vdr.vnsi:
  • [cmake] remove usage of kodi-platform (PR:118, 1 commit, 2 files changed)
pvr.wmc:
  • [cleanup] remove unused kodiplatform dependency (PR:69, 1 commit, 4 files changed)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (ca3632d8) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , pvr.waipu (c6d131ae, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (dec20f6e) , pvr.mythtv (56176ab2) , pvr.hts (9943d05c) , pvr.pctv (af868144) , pvr.stalker (f926a517) , pvr.filmon (5265b914) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (70732ccd) , pvr.wmc (38de15a2) , pvr.nextpvr (e72e4293) , pvr.njoy (fe6d356e) , pvr.teleboy (9aa341a3) , pvr.vdr.vnsi (1defc992) , pvr.vuplus (ecfc0472) , pvr.dvbviewer (324db50d) , pvr.dvblink (a960e89b) , pvr.hdhomerun (ebeb5dc8) , pvr.iptvsimple (ee94b98f) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (045125be) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
18.8-36, 5 May 2019: Based off OSMC commit (00fefb674e6f) and xbmc (ae31c4f4)
XBMC:
  • [PVR] Create EPG when a PVR channel has been dynamically added at runtime (PR:16048, 1 commit, 1 file changed)
  • MusicExtensions: Add dtshd as that extension is used for commercial dtshd (PR:16031, 1 commit, 1 file changed)
  • [python] xbmcvfs file.seek() - whence should be optional (PR:15662, 2 commits, 1 file changed)
  • Simplify some boolean expressions in RetroPlayer (PR:16008, 1 commit, 6 files changed)
  • Improve ā€˜Choose Artā€™ dialog (PR:15747, 2 commits, 2 files changed)
  • [python] xbmcvfs - add file.tell() function (PR:15663, 1 commit, 1 file changed)
  • added: video info dialog for movie sets (PR:15315, 3 commits, 7 files changed)
  • Remove 3:2 pullback from current check (PR:16052, 1 commit, 1 file changed)
pvr.teleboy:
  • [cmake] remove usage of kodi-platform (PR:19, 1 commit, 2 files changed)
pvr.vuplus:
  • Custom groups and timer fix matrix (PR:215, 6 commits, 20 files changed)
audioencoder.flac (7bce2e5a) , audioencoder.lame (476f4b2e) , audioencoder.vorbis (acd7c796) , audioencoder.wav (673c6088) , inputstream.adaptive (ca3632d8) , inputstream.rtmp (ce68b77a) , peripheral.xarcade (d218f0dc) , peripheral.joystick (910bd3dc) , imagedecoder.raw (41a370db) , peripheral.steamcontroller (884d5f0c) , game.libretro (eebfdf78) , game.libretro.2048 (6c6c41ed) , game.libretro.beetle-gba (566630f5) , game.libretro.fceumm (576fa983) , game.libretro.gw (9d745c2b) , game.libretro.beetle-pce-fast (4c7cb4fa) , game.libretro.bnes (6995dd3d) , game.libretro.nestopia (4d44431c) , game.libretro.bsnes-mercury-balanced (4d5d2538) , game.libretro.mame2000 (3d01798b) , game.libretro.mame2003 (b86620c4) , game.libretro.bluemsx (0e6f713a) , game.libretro.vecx (20edd48c) , game.libretro.mame2003_plus (776d158f) , game.libretro.gambatte (7493bd05) , game.libretro.beetle-bsnes (5eb2843c) , game.libretro.meteor (e582cc1d) , game.libretro.mgba (13945641) , game.libretro.vba-next (9735a9f4) , game.libretro.quicknes (4816e6a3) , game.libretro.scummvm (76da70af) , game.libretro.snes9x (d700274b) , game.libretro.stella (f5b7d3bf) , game.libretro.dosbox (5103cd15) , game.libretro.vbam (2e34c8fd) , game.libretro.yabause (216f5f3e) , game.libretro.genplus (4f0803e9) , game.libretro.mame (576c4ed5) , game.libretro.bsnes-mercury-accuracy (a83b6e6a) , pvr.waipu (c6d131ae, +1), pvr.sledovanitv.cz (6fe56379) , pvr.argustv (dec20f6e) , pvr.mythtv (56176ab2) , pvr.hts (9943d05c) , pvr.pctv (af868144) , pvr.stalker (f926a517) , pvr.filmon (5265b914) , pvr.octonet (63ef3635) , pvr.zattoo (0bef3f62) , pvr.vbox (70732ccd) , pvr.wmc (38de15a2) , pvr.nextpvr (e72e4293) , pvr.njoy (fe6d356e) , pvr.teleboy (926d5846) , pvr.vdr.vnsi (1defc992) , pvr.vuplus (ecfc0472) , pvr.dvbviewer (324db50d) , pvr.dvblink (a960e89b) , pvr.hdhomerun (ebeb5dc8) , pvr.iptvsimple (ee94b98f) , pvr.demo (f5458316) , pvr.mediaportal.tvserver (045125be) , vfs.libarchive (2ba11021) , vfs.rar (e6b5114a) , vfs.sftp (3ab3969b)
This also appears to be happening to me Vero 4k video freeze for 3-5 seconds on last frame after a pause that was longer than 10 seconds - #33 by Nickelig
Only started on the last two or three nightly builds
https://paste.osmc.tv/efeqeyahoj
Happens on Blu-ray and 4k rips
18.8-37, 5 May 2019: Based off OSMC commit (df859cdf5) and xbmc (aba6aa94)
OSMC:
  • Fix skin loading with profiles
XBMC:
  • [cmake] use treedata instead of add_directory for omxplayer and rpi windowing (PR:16020, 3 commits, 11 files changed)
  • Revert ā€œVideoPlayerCodec: Ask Demuxer to seek for usā€ (PR:16061, 1 commit, 1 file changed)
