Thanks.
So can you confirm what ~/.smb/smb.conf should look like so we can make this change to OSMC?
Cheers,
Thanks.
Cheers,
Mine looks like this:
But what if somebody wants to use SMB1?
I changed this:
client min protocol = SMB2
to this:
client min protocol = SMB1
And it no longer worked.
It’s probably best to change it to that; as SMBv1 is quite rare now.
Legacy devices can still be accessed via fstab
Okay I did a bunch of testing.
If I leave SMB 1, 2, and 3 all enabled on my server.
If I set my smb.conf file to this:
[quote][global]
preferred master = no
local master = no
domain master = no
client lanman auth = yes
lanman auth = yes
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=6$
lock directory = /home/osmc/.smb/
client use spnego = no
client ntlmv2 auth = no
name resolve order = bcast host
client max protocol = SMB3
[/quote]
(I only added client max protocol = SMB3, left everything else alone)
Then Kodi will use SMB v3.
Without the client max protocol, kodi uses SMB1.
Without the client max protocol, AND with ntlmv2 auth set to yes, SMB1 doesn’t work. Endless password prompts.
So again, the most widely compatible bet is to just add:
The safest/most secure bet would be to add these 3:
[quote] client ntlmv2 auth = yes
client max protocol = SMB3[/quote]
(You don’t add client ntlmv2 auth = yes, you change the no to yes)
I can confirm that below config works against samba 4.5.10 server. But it also work if we comment out the “client max protocol = SMB3” I am not sure what advantages it has to limit the max protocol.
[global]
local master = no
domain master = no
lanman auth = yes
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=65536 SO_SNDBUF=65536
client use spnego principal = no
Did you try
without “client max protocol = SMB3”
‘client max protocol = default’ used to be ‘NT1’ in many Samba versions.
In Samba 4.3.0 they changed it to ‘SMB3_11’ but we are not on that version yet. By setting the value we are kind of enabling it with our version.
I’m sure that your server negotiatied down to SMB1. Unless ‘server min protocol = SMB2’ is set on your server this still happens.
I’m with bedub1
(doesn’t break browsing)
client ntlmv2 auth = yes client min protocol = SMB2 client max protocol = SMB3
(breaks browsing)
name resolve order = bcast ... just tested it, doesn’t bring back browsing when SMB1 is disabled.
I have now made these changes default in Kodi, so hopefully there’s no need for any further tinkering.
Thank you @nAFutro @fzinken @bedub1 @Tom_Doyle. This will help a lot of users ![]()
