Running Kodi 14.1 on my Raspberry Pi 2. I have trouble setting up Kodi as the renderer in BubbleUPnP on my phone.
UPnP is enabled in Kodi.
I am taking the following steps:
Restart the Pi;
Check BubbleUPnP: Kodi is available as renderer; Selecting
Kill BubbleUPnP, wait approximately 5 minutes
Start BubbleUPnP again, now the app will try to use the Kodi renderer, but fails, reverts to local, and Kodi is no longer in the options list
The only way to make it reappear is by restarting the Pi.
Apps similar to BubbleUPnP exhibit the same behaviour.
Is there a configuration setting in OSMC / Kodi that I am missing?
Hi Im using Bubbleupnp with osmc and it´s working great. All i´ve done is to enable all four entries under the UPNP setup in osmc. After that kodi shows up in Bubbleupnp.
Have you tried the tweaks in Bubblepnp? The ones i´ve enabled are “Gapless control”,“Mine-type check” “Use eventing” and “server side search”. There´s also a “Blast alive messages” setting there might be worth a shot.
I use Bubbleupnp with osmc for several hours (for internet radio and music stored on the phone) on a daily basis, with the raspberry pi 2 so it should also be possible for you. Hope you figure out whats wrong. Good luck
Thank you Skov for your help. My settings mirror yours at the moment. Unfortunately this does not solve the problem.
I have also tried this with an Xbian image and the results are the same. Reboot, find Kodi, Try to reconnect after 3 - 5 minutes, to find that it’s gone. Must be something in my network then.
I have the same problem. But reboot not needed. Only on/off Settings -> Services -> UPnP/DLNA -> Allow remote control via UPnP for response Kodi in BubbleUPNP. [Expert mode settings in Kodi].
