Basically, when I want to connect to any of KNOWN (previously connected) wifi networks, the system asks me for password all the time. Luckily, when the system auto-connects, it conveniently remembers it, but inconveniently doesn’t, when I hit “connect”.
What’s up with that? I can’t believe that is a normal behavior.
I think it makes sense to get some logs when you see this prompt and when the connection doesn’t automatically work so we can see why this is happening.
Which elements should I enable to get some usable logs?
Or maybe differently, where are the wifi configs?
Uploading logs via My OSMC should give us enough information.
To me this sounds like a PSU that’s about to fail.
