Not having any particular issue, but noticed that kodi.bin is using a constant higher amount of CPU on one core, even when not active. i.e. I’m not using the Vero 4K+ input.
State of the Vero 4K+
Latest version
PlexKodiConnect
Customise Menus to hide some of the top level options
Seems wasteful (cpu/energy wise) to have it redrawing constantly when not in use. I wonder if maybe an option could be added if it’s sitting at the same (non home) screen for X time, back it out to the home menu, or suspend updates till a user input occurs?
e.g. options something like this:
Return to home screen after (5|10|30|60) minutes of no user input.
Suspend display updates after (5|10|30|60) minutes of no user input. Any user input will resume display updates.
