I’m trying to set up my vero5 to build a couple binary addons. I know I had done this back in the Leia days on the 4k. I’m looking in the osmc repo from github, but for the life of me I cannot find your kodi/xbmc fork code in there.
I assume you are building off an osmc oriented fork of xbmc? or do you roll all your osmc updates directly back into the mainline xbmc repo now and should I just clone main xbmc repo to set up building the addons off that instead?
Yeah, that’s right. Since I fiddle with build script so much, I got it mixed up.
I should probably resume my efforts on emulators again. The arm binary repo is so old, would be great to have arm64 version of it. Or focus some efforts on moonlight client again.
I want to build against the Nexus branch (since that is what is currently running in osmc). However, the makefile for the Nexus branch does not appear to have vero5 as an option.
We do backporting – but once a new Kodi release is out, they don’t do backporting.
The Nexus branch you see will be the initial porting branch and won’t be synced with new changes.
I’ve discovered that the kodi addon as-is is somewhat behind the times compared to the source project… It is using an older, out-of-date version of the presets, and doesn’t match the current organization (projectM now has a larger set of default presets organized into muti-level nested categories) and it is missing the texture files (that many presets use to generate their graphics). It also forces you to rotate though the list of presets from whatever pack you choose (no option to just stay on one) and does not allow you to pick/choose the list of your preferred presets.
I also think it would be a cool feature to change the preset when the song changes. I assume the addon can get notified of that, but I’ve never looked into that side of things.
I think I’m gonna end up forking it to modernize the presets and settings management.
meanwhile, if you want to roll it into the osmc release, here is my build script:
#!/bin/bash
cd visualization.projectm
#git pull
mkdir build
cd build
cmake -DADDONS_TO_BUILD=visualization.projectm \
-DADDON_EXTRA_ARGS="-DAPP_RENDER_SYSTEM=gles" \
-DADDON_SRC_PREFIX=../.. \
-DCMAKE_BUILD_TYPE=Debug \
-DCMAKE_INSTALL_PREFIX=../../xbmc/kodi-build/addons \
-DPACKAGE_ZIP=1 \
../../xbmc/cmake/addons
make
Although it does not generate a zip (which I thought the ZIP cmake arg was supposed to make it do… ), however, the unziped addon is available under the build/.install directory
btw, the current “Omega” branch of of the addon works just fine when dropped into Nexus (at least on the vero5)
How would you adapt this cmake command line to use armv7-toolchain-osmc to make sure to build for arch armv7 in case you do not build from same arch (so not on the vero 5 it-self).
Thanks, works perfectly to build inside the chroot.
(Sorry for the confusion, i thought at first the path of the toolchain was supposed to be passed as an extra args…)
