I have an RPI 3B OSMC instance in a second home that is within a network connected to the internet via a 4G modem/router.
The inderlying ISP issue a CGNAT external IP address that is annoyingly changed every 6 hours, they literally drop the connection forcing a modem reconnection every 6 hours after the modem/router is booted.
Tailscale is installed on the OSMC instance and accesses NFS shares on a NAS on my home network.
The OSMC instance is configured to rescan the NAS shares on each restart.
Tailscale gracefully deals with the 6 hourly change in external IP address, there is an interruption but the NFS mounts can be accesses within few seconds.
OSMC also initially appears ok but if something is being watched then buffering starts every so often. If the player is stopped and started the buffering remains.
Eventually, OSMC crashes and restarts whether something is being watched or not.
Sep 13 23:01:53 osmc-Bexhill kernel: ------------[ cut here ]------------
Sep 13 23:01:53 osmc-Bexhill kernel: WARNING: CPU: 1 PID: 501 at lib/refcount.c:87 refcount_dec_not_one+0xb4/0xc4
Sep 13 23:01:53 osmc-Bexhill kernel: refcount_t: underflow; use-after-free.
Sep 13 23:01:53 osmc-Bexhill kernel: Modules linked in: rpcsec_gss_krb5 xt_MASQUERADE xt_tcpudp xt_mark binfmt_misc tun nf_tables nfnetlink ip6table_nat ip6table_filter ip6_tables cmac 8021q garp stp algif_hash llc aes_arm_bs crypto_simd cryptd algif_skcipher af_alg bnep iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle iptable_filter vc4 snd_soc_hdmi_codec hci_uart cec drm_kms_helper btbcm brcmfmac bluetooth snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm bcm2835_codec(C) snd_timer ecdh_generic ecc brcmutil snd bcm2835_v4l2(C) v4l2_mem2mem bcm2835_isp(C) bcm2835_mmal_vchiq(C) syscopyarea videobuf2_dma_contig sysfillrect videobuf2_vmalloc sysimgblt fb_sys_fops sha256_generic videobuf2_memops videobuf2_v4l2 videobuf2_common cfg80211 videodev raspberrypi_hwmon rfkill i2c_bcm2835 mc vc_sm_cma(C) fixed uio_pdrv_genirq uio drm fuse drm_panel_orientation_quirks backlight ip_tables x_tables ipv6
Sep 13 23:01:53 osmc-Bexhill kernel: CPU: 1 PID: 501 Comm: kodi.bin Tainted: G C 5.15.92-1-osmc #1
Sep 13 23:01:53 osmc-Bexhill kernel: Hardware name: BCM2835
Sep 13 23:01:53 osmc-Bexhill kernel: Backtrace:
Sep 13 23:01:53 osmc-Bexhill kernel: [<80be11e8>] (dump_backtrace) from [<80be1430>] (show_stack+0x20/0x24)
Sep 13 23:01:53 osmc-Bexhill kernel: r7:00000057 r6:00000000 r5:80e07480 r4:60010013
Sep 13 23:01:53 osmc-Bexhill kernel: [<80be1410>] (show_stack) from [<80be6abc>] (dump_stack_lvl+0x70/0x94)
Sep 13 23:01:53 osmc-Bexhill kernel: [<80be6a4c>] (dump_stack_lvl) from [<80be6af8>] (dump_stack+0x18/0x1c)
Sep 13 23:01:53 osmc-Bexhill kernel: r7:00000057 r6:00000009 r5:80745fbc r4:80e44a24
Sep 13 23:01:53 osmc-Bexhill kernel: [<80be6ae0>] (dump_stack) from [<801276a8>] (__warn+0x98/0x12c)
Sep 13 23:01:53 osmc-Bexhill kernel: [<80127610>] (__warn) from [<80be1a2c>] (warn_slowpath_fmt+0xa4/0xe4)
Sep 13 23:01:53 osmc-Bexhill kernel: r7:80745fbc r6:00000057 r5:80e44a24 r4:80e44a60
Sep 13 23:01:53 osmc-Bexhill kernel: [<80be198c>] (warn_slowpath_fmt) from [<80745fbc>] (refcount_dec_not_one+0xb4/0xc4)
Sep 13 23:01:53 osmc-Bexhill kernel: r8:83424040 r7:83424040 r6:7f564114 r5:835b2710 r4:00000001
Sep 13 23:01:53 osmc-Bexhill kernel: [<80745f08>] (refcount_dec_not_one) from [<7f52f664>] (vc4_bo_dec_usecnt+0x34/0xe0 [vc4])
Sep 13 23:01:53 osmc-Bexhill kernel: r5:835b2710 r4:835b2600
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f52f630>] (vc4_bo_dec_usecnt [vc4]) from [<7f55661c>] (vc4_cleanup_fb+0x3c/0x40 [vc4])
Sep 13 23:01:53 osmc-Bexhill kernel: r7:83424040 r6:7f564114 r5:86d70980 r4:00000004
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f5565e0>] (vc4_cleanup_fb [vc4]) from [<7f669144>] (drm_atomic_helper_cleanup_planes+0x6c/0x80 [drm_kms_helper])
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f6690d8>] (drm_atomic_helper_cleanup_planes [drm_kms_helper]) from [<7f53b358>] (vc4_atomic_commit_tail+0x420/0x790 [vc4])
Sep 13 23:01:53 osmc-Bexhill kernel: r7:83424040 r6:00000000 r5:8438c000 r4:86d70980
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f53af38>] (vc4_atomic_commit_tail [vc4]) from [<7f66d104>] (commit_tail+0xac/0x190 [drm_kms_helper])
Sep 13 23:01:53 osmc-Bexhill kernel: r10:86d70980 r9:00000000 r8:7f56d224 r7:00001cb4 r6:642e2d2a r5:00000000
Sep 13 23:01:53 osmc-Bexhill kernel: r4:86d70980
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f66d058>] (commit_tail [drm_kms_helper]) from [<7f66dc1c>] (drm_atomic_helper_commit+0x1f4/0x218 [drm_kms_helper])
Sep 13 23:01:53 osmc-Bexhill kernel: r9:00000000 r8:8438c000 r7:00000000 r6:00000000 r5:00000000 r4:86d70980
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f66da28>] (drm_atomic_helper_commit [drm_kms_helper]) from [<7f108680>] (drm_atomic_commit+0x54/0x60 [drm])
Sep 13 23:01:53 osmc-Bexhill kernel: r9:00000000 r8:00000000 r7:00000004 r6:8438c000 r5:86d70980 r4:00000000
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f10862c>] (drm_atomic_commit [drm]) from [<7f12b294>] (drm_mode_atomic_ioctl+0x8f4/0xab0 [drm])
Sep 13 23:01:53 osmc-Bexhill kernel: r7:00000004 r6:81dc7040 r5:8818be3c r4:00000000
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f12a9a0>] (drm_mode_atomic_ioctl [drm]) from [<7f0ee4ac>] (drm_ioctl_kernel+0xcc/0x174 [drm])
Sep 13 23:01:53 osmc-Bexhill kernel: r10:00000038 r9:828f6a00 r8:828f6a00 r7:8818be3c r6:7f12a9a0 r5:8438c000
Sep 13 23:01:53 osmc-Bexhill kernel: r4:00000002
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f0ee3e0>] (drm_ioctl_kernel [drm]) from [<7f0ee740>] (drm_ioctl+0x1ec/0x3a8 [drm])
Sep 13 23:01:53 osmc-Bexhill kernel: r8:000000bc r7:8818be3c r6:7f135d04 r5:00000038 r4:c03864bc
Sep 13 23:01:53 osmc-Bexhill kernel: [<7f0ee554>] (drm_ioctl [drm]) from [<803e168c>] (sys_ioctl+0x118/0xc0c)
Sep 13 23:01:53 osmc-Bexhill kernel: r10:82bdc408 r9:00000000 r8:826f9840 r7:7ea8baa8 r6:826f9841 r5:00000000
Sep 13 23:01:53 osmc-Bexhill kernel: r4:c03864bc
Sep 13 23:01:53 osmc-Bexhill kernel: [<803e1574>] (sys_ioctl) from [<80100040>] (ret_fast_syscall+0x0/0x1c)
Sep 13 23:01:53 osmc-Bexhill kernel: Exception stack(0x8818bfa8 to 0x8818bff0)
Sep 13 23:01:53 osmc-Bexhill kernel: bfa0: 07c02e48 7ea8baa8 00000000 c03864bc 7ea8baa8 00000000
Sep 13 23:01:53 osmc-Bexhill kernel: bfc0: 07c02e48 7ea8baa8 c03864bc 00000036 7ea8baa8 0755dfd0 080cfd54 00000000
Sep 13 23:01:53 osmc-Bexhill kernel: bfe0: 75ee7090 7ea8ba7c 75ecef17 759d9418
Sep 13 23:01:53 osmc-Bexhill kernel: r10:00000036 r9:8818a000 r8:80100244 r7:00000036 r6:c03864bc r5:7ea8baa8
Sep 13 23:01:53 osmc-Bexhill kernel: r4:07c02e48
Sep 13 23:01:53 osmc-Bexhill kernel: ---[ end trace 94498879b00c5cab ]---
Any hints on how to proceed?
