Hey everyone
Please excuse the noob question but after the last update I installed I am stuck in an endless sad face loop… Don’t really know what to do. So I logged into the Pi with SSH and dumped these logs:
root@Sin:/home/osmc# paste-log /var/log/apt/history.log
http://paste.osmc.io/yuwekawulo
root@Sin:/home/osmc# paste-log /var/log/apt/term.log
http://paste.osmc.io/aqilifehuc
root@Sin:/home/osmc# paste-log /home/osmc/.kodi/temp/kodi.log
http://paste.osmc.io/aluziyibem
I see there are a few errors in the Kodi Log → however I have no idea on how to tackle them.
Any ideas? Need any other logs?
You shouldn’t be running apt-get upgrade
, always apt-get dist-upgrade
If you ran apt-get upgrade
you will have problems. You should always use apt-get dist-upgrade
Doing the following will probably resolve the issue:
sudo apt-get update
sudo apt-get -f dist-upgrade
reboot
filthpig:
If the problem persists after the above, grab-logs -A
will paste all useful logs in one go.
Thanks for the replies guys.
Unfortunately it didn’t work, I’m still in a sad face loop…
here’s the log dump
http://paste.osmc.io/owivogeyux
Are you sure you ran apt-get -f dist-upgrade as I suggested ? There is no evidence of this in the log file you just provided…
This is still the last history.log enty:
Start-Date: 2016-04-14 19:29:02
Commandline: apt-get upgrade
Upgrade: python-ldb:armhf (1.1.17-2+deb8u1, 1.1.20-0+deb8u1), libldb1:armhf (1.1.17-2+deb8u1, 1.1.20-0+deb8u1), libtdb1:armhf (1.3.1-1, 1.3.6-0+deb8u1), samba:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), samba-common-bin:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), python-talloc:armhf (2.1.1-2, 2.1.2-0+deb8u1), libtalloc2:armhf (2.1.1-2, 2.1.2-0+deb8u1), samba-common:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), libtevent0:armhf (0.9.21-1, 0.9.25-0+deb8u1), python-samba:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), tdb-tools:armhf (1.3.1-1, 1.3.6-0+deb8u1), python-tdb:armhf (1.3.1-1, 1.3.6-0+deb8u1), samba-dsdb-modules:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), libsmbclient:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), samba-libs:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2), base-files-osmc:armhf (1.9.0, 1.9.1), libwbclient0:armhf (4.1.17+dfsg-2+deb8u2, 4.2.10+dfsg-0+deb8u2)
End-Date: 2016-04-14 19:33:12
duhr
14 April 2016 20:00
6
Same here after updating with the built-in updater.
Don’t threadjack.
You’ve already posted twice. If you want the issue solved, start a new post.
Indeed.
Please tell me where you read this advice so I can ask if they can amend their instructions
Thank you all
DBMandrake:
you’re right… so I did it again →
http://paste.osmc.io/taquxuvoga
but it still doesn’t show up in the logs… so I’ll just paste my console:
root@Sin:/home/osmc# sudo apt-get update
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://security.debian.org jessie/updates InRelease
Hit http://apt.osmc.tv jessie InRelease
Hit http://ftp.debian.org jessie Release.gpg
Get:1 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [1996 B]
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Get:2 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Get:3 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [1228 B]
Get:4 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://security.debian.org jessie/updates/non-free Translation-en
Get:5 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Hit http://ftp.debian.org jessie/main armhf Packages
Hit http://ftp.debian.org jessie/contrib armhf Packages
Hit http://ftp.debian.org jessie/non-free armhf Packages
Hit http://ftp.debian.org jessie/contrib Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Hit http://ftp.debian.org jessie/non-free Translation-en
Ign http://apt.osmc.tv jessie/main Translation-en
Fetched 6719 B in 38s (172 B/s)
Reading package lists... Done
root@Sin:/home/osmc# sudo apt-get -f dist-upgrade
Building dependency tree
Calculating upgrade... The following packages were automatically installed and are no longer required:
apt-transport-https libbluray1 libgssapi3-heimdal libheimntlm0-heimdal
libkdc2-heimdal rbp2-image-4.4.3-3-osmc
Use 'apt-get autoremove' to remove them.
Done
root@Sin:/home/osmc# reboot
read it here → http://kodi.wiki/view/Kodibuntu#How_to_upgrade_Kodi
Ah, Kodibuntu is not OSMC.
Maybe when we do our x64 port we can take that spot
We’ll see.
ooops, sorry.
Do you think that at this point I should rebuild?
Well interesting enough no one has asked you the basic question, which skin are you running?
Try mv .kodi .kodi_backup
and reboot
Using Arctic:Zephyr
Oh my god, that actually worked! I’ll try to recover what I can from the backup and see what might ha ve caused the crash (be it addons, theme or what not). Thanks!
No need, that was just to find out!
Just do
mv .kodi_backup .kodi
nano .kodi/userdata/guisettings.xml
search for the line starting and change it to <skin default="true">skin.osmc</skin>
Save the file when exiting with CTRL-X
Perfect, thank you so much!
Artic:Zephyr crashes when I try to select it as theme… I’ll try to re-download and install it.
Thanks all, and excuse the n00b thread
Just to put my two cents here. Same problem, same symptoms. And your solution worked flawlessly. It seems Arctic:Zephyr is broken for the current OSMC release. A pity, but better this than reinstall.
Thanks A LOT for the help.
